Need help configuring a tunnel interface (basic mpls with rsvp)
admin_2
Level 3
Level 3
I am trying to configure a tunnel interface with a specific destination. Even though that destination is reachable (I can ping it) I get the output below. "Path not valid... destination IP address not found."
Can anybody shed some light on why this is?
cisco7206#show mpls tr tun
Name: cisco7206_t0 (Tunnel0) Destination: 1.0.0.1
Status:
Admin: up Oper: down Path: not valid Signalling: Down
path option 1, type dynamic
Config Parameters:
Bandwidth: 0 kbps (Global) Priority: 7 7 Affinity: 0x0/0xFFFF
Metric Type: TE (default)
AutoRoute: disabled LockDown: disabled Loadshare: 0 bw-based
auto-bw: disabled
History:
Tunnel:
Time since created: 2 hours, 7 minutes
Path Option 1:
Last Error: PCALC:: Destination IP address, 1.0.0.1, not found
cisco7206#
5 Replies 5
tyossef
This may be due to a number of things, chief among them config problems. How does your tunnel config look like? Do you have RSVP configured along the path? How does
show mpls traffic-eng topology look like? I cannot tell from only this show command output what the problem could be, hopefully others can...
--tamrat
Not applicable
Hi. My tunnel config is (the tunnel dest is 1.0.0.2, not 1.0.0.1 as shown in my original post):
interface Tunnel0
ip unnumbered Loopback0
tag-switching ip
tunnel destination 1.0.0.2
tunnel mode mpls traffic-eng
tunnel mpls traffic-eng autoroute announce
tunnel mpls traffic-eng path-option 1 dynamic
end
I have rsvp configured all along the path.
The show mpls tr top looks like:
cisco7206#show mpls tr top
My_System_id: 99.99.99.99, Globl Link Generation 2
Signalling error holddown: 10 sec
IGP Id: 99.99.99.99, MPLS TE Id:99.99.99.99 Router Node
link[0 ]:DR Intf Address: 1.0.0.1, gen:2
frag_id 0, Intf Address:1.0.0.1
TE metric:1, IGP metric:1, attribute_flags:0x0
physical_bw: 100000 (kbps), max_reservable_bw_global: 10000000 (kbps)
max_reservable_bw_sub: 0 (kbps)
Global Pool Sub Pool
Total Allocated Reservable Reservable
BW (kbps) BW (kbps) BW (kbps)
bw[0]: 0 10000000 0
bw[1]: 0 10000000 0
bw[2]: 0 10000000 0
bw[3]: 0 10000000 0
bw[4]: 0 10000000 0
bw[5]: 0 10000000 0
bw[6]: 0 10000000 0
bw[7]: 0 10000000 0
link[1 ]:DR Intf Address: 2.0.0.1, gen:2
frag_id 1, Intf Address:2.0.0.1
bw[0]: 0 10000000 0
bw[1]: 0 10000000 0
bw[2]: 0 10000000 0
bw[3]: 0 10000000 0
bw[4]: 0 10000000 0
bw[5]: 0 10000000 0
bw[6]: 0 10000000 0
bw[7]: 0 10000000 0
cisco7206#
Ok, so you have RSVP configured and have enough BW on the tunnels. Could you check if you are propagating TE info into OSPF/ISIS? Is 1.0.0.2 one or more hops away? Could you do a traceroute to 1.0.0.2? And also do a show mpls interfaces?
I do not see anything wrong thus far, but perhaps one of the things I am asking you for here will uncover the problem.
--tamrat
Not applicable
I have made some progress. The original problem seems to have been a bandwidth problem. Now, when I give the command "debug ip rsvp all" I get:
sco7206#
cisco7206#
cisco7206#
*Mar 24 01:00:43.734: RSVP-API 99.99.99.99_443->1.0.0.2_1[0.0.0.0]: Failed to cr
eate proxy Path state, reason: Invalid route specification
cisco7206#
repeatedly. Does anybody know what this means? If I do the command "show mpls tr top path tunnel 1"
I get:
cisco7206#show mpls tr top path tunnel 1
Query Parameters:
Destination: 1.0.0.2
Bandwidth: 10
Priorities: 5 (setup), 5 (hold)
Affinity: 0x0 (value), 0xFFFF (mask)
Query Results:
Min Bandwidth Along Path: 80 (kbps)
Max Bandwidth Along Path: 100000 (kbps)
Hop 0: 1.0.0.1 : affinity 00000000, bandwidth 100000 (kbps)
Hop 1: 1.0.0.2 : affinity 00000000, bandwidth 80 (kbps)
Hop 2: 1.0.0.2
cisco7206#
which shows a valid path.
Make sure that you the loopback interface address of the the egress router as the destination address. Also make sure you use the loopback interface for the "mpls traffic-eng router-id" command.
Hope this helps,
