not able to ping in l2 xconnect
Haris P
Level 4
Level 4
Dears ,
I'm trying to configure an xconnect between two of my PE routers and the VC showing up but i can't ping the hosts in the other side of VLAN .Any Clues ?
#sh mpls l2transport vc detail
Local interface: Gi6/0.23 up, line protocol up, Eth VLAN 23 up
  Destination address: 172.21.15.1, VC ID: 23, VC status: up
    Next hop: 172.21.11.1
    Output interface: Gi6/0.101, imposed label stack {78}
  Create time: 02:41:12, last status change time: 00:25:17
  Signaling protocol: LDP, peer 172.21.15.1:0 up
    MPLS VC labels: local 133, remote 78
    Group ID: local 0, remote 0
    MTU: local 1500, remote 1500
My config is as given below and my ios is slot0:c7200-p-mz.123-24.bin
pseudowire-class test
encapsulation mpls
interface GigabitEthernet6/0.23
encapsulation dot1Q 23
xconnect 172.21.15.1 23 pw-class test
regards
Haris P
10 Replies 10
Ha Dao
- You use the same vlan at both of 2 sites or use vlan rewrite feature ?
- What source ip add did you use to ping the hosts at the other sites ?, were they in the same subnet ?
i use both side same vlan ..how do  i use vlan rewrie feature never tried this
yes they were in same subnet
hi
please check the config
http://www.mplsvpn.info/2011/12/implementation-of-eompls-ethernet-over.html
vlan rewrite feature is not used by all the platforms. Please let us know which platform you are using.
regards
shivlu jain
Try this
xconnect 172.21.15.1 23 encapsulation mpls pw-class test
not working also with the commands you specified , im seeing thatVC is up , but under statitics packets receive 0 ,send 0
encapsulation mpls
interface GigabitEthernet0/3.102
encapsulation dot1Q 102
no cdp enable
xconnect 10.101.0.1 102 encapsulation mpls pw-class test
Output interface: Fa2/0, imposed label stack {298 3502}
Create time: 00:26:06, last status change time: 00:01:06
Signaling protocol: LDP, peer 10.101.0.1:0 up
MPLS VC labels: local 143, remote 3502
Group ID: local 4, remote 5
Remote interface description: test
Sequencing: receive disabled, send disabled
VC statistics:
packet totals: receive 0, send 0
byte totals: receive 0, send 0
packet drops: receive 0, send 0
edikonimos
It looks like, you haven't configured right on the Trunk inteface.. X-connect seems to be working just fine but no input packets came through the sub interface..
For test propused, you might x-connect the whole Gigabit Interface by moving the xconnect on the major interface.
Are you trying with a switch connected on the Gi6/0?
In both ends my hosts are connected in acces ports and the PE is connected to trunk port of the switch . it is as shown below
In fact i tried configuring an IP in the same range of the PC on my router dot1Q interface and i was able to ping the host on that side without any problem ,so i dont think that it is not a connectivity issue
PC1...Access vlan 102 ...switch ........trunk......Switch.......trunk.....PE1-------------------PE2....trunk.....switch....trunk....Access switch.
regards
Haris
http://www.cisco.com/en/US/docs/ios/12_0s/feature/guide/fsatom28.html#wp1047206
You xconnect config seems to be just fine.... and for 7200 you don't need to set remote id number for xconnect.
In my opinion it seems strange that dont hane not even one packet in on the subinterface.
You should at least have input packets from you switch ... and dropped after.
Please have in mind that xconnect passthough layer 2 BPDUs in 7200, which means tha CDP should see an VLAN mismatch and PerVlan Spanning Tree most likely to error disable the port, since it receive BPDU with different Vlan ID.
David Sharkat
Try to check the mtu
I saw that the out interface is fast and the gige interface is ingress
Can you please send us the ldp binding ?
You can also do some debug to see where the problem
Sent from Cisco Technical Support Android App
The below is my debugs .... I'm not seeing any STP passing through the switches thru the l2 xconnect , both side switches as root for the VLANs 102....running me crazy !!
Dec  5 18:27:25.202: AToM MGR [10.101.0.1, 102]: Event ldp down, state changed
from established to local standby
Dec  5 18:27:25.202: AToM MGR [10.101.0.1, 102]: Remote end down, vc is down
Dec  5 18:27:25.202: AToM SMGR [10.101.0.1, 102]: Processing imposition update
, vc_handle 502B2BC0, update_action 0, remote_vc_label 84
Dec  5 18:27:25.202: AToM SMGR [10.101.0.1, 102]: Imposition Disabled
Dec  5 18:27:25.202: AToM SMGR [10.101.0.1, 102]: Processing disposition updat
e, vc_handle 502B2BC0, update_action 0, local_vc_label 172
Dec  5 18:27:25.202: AToM MGR [10.101.0.1, 102]: Event local up, state changed
from local standby to local standby
Dec  5 18:27:25.202: AToM MGR [10.101.0.1, 102]: Take no action
Dec  5 18:27:25.202: AToM SMGR: TFIB scan started
Dec  5 18:27:25.214: AToM SMGR: TFIB scan complete
Dec  5 18:27:28.914: AToM SMGR: Processing TFIB event for 10.101.0.1
Dec  5 18:27:32.066: %LDP-5-NBRCHG: LDP Neighbor 172.16.12.6:0 (1) is UP
Dec  5 18:27:32.142: AToM SMGR: Processing TFIB event for 10.101.0.1
Dec  5 18:27:32.854: %LDP-5-NBRCHG: LDP Neighbor 10.101.0.1:0 (2) is UP
Dec  5 18:27:32.858: AToM MGR [10.101.0.1, 102]: Event ldp up, state changed f
rom local standby to local ready
Dec  5 18:27:32.858: AToM MGR [10.101.0.1, 102]: Advertise local vc label bind
ing
Dec  5 18:27:32.970: AToM MGR [10.101.0.1, 102]: Event remote up, state change
d from local ready to establishing
Dec  5 18:27:32.970: AToM MGR [10.101.0.1, 102]: Remote end up
Dec  5 18:27:32.974: AToM MGR
[10.101.0.1, 102]: Event remote validated, state
changed from establishing to established
Dec  5 18:27:32.974: AToM MGR [10.101.0.1, 102]: Validate vc, activating data
plane
Dec  5 18:27:32.974: AToM SMGR [10.101.0.1, 102]: Processing imposition update
, vc_handle 502B2BC0, update_action 3, remote_vc_label 84
Dec  5 18:27:32.974: AToM SMGR [10.101.0.1, 102]: Imposition Programmed, Outpu
t Interface: Gi0/1
Dec  5 18:27:32.974: AToM SMGR [10.101.0.1, 102]: Processing disposition updat
e, vc_handle 502B2BC0, update_action 3, local_vc_label 172
Dec  5 18:27:32.990: AToM SMGR: Processing TFIB event for 10.101.0.1
Dec  5 18:27:32.990: AToM SMGR [10.101.0.1, 102]: Imposition Programmed, Outpu
t Interface: Gi0/1
