OSPF as CE-PE Routing Protocol
nadeemr
A customer has about 40 sites in MPLS VPN. All sites are stub and have point-to-point connections to Service provider PE's. Few of these sites have dual point-to-point links to PE's. The customer wants to use OSPF as CE-PE routing protocol. Can someone guide what should be the optimal OSPF topology for this network and how the OSPF areas should be design?
15 Replies 15
I agreed with you totally from technical routing/security solution point of view. However, not every CE IOS version will support BGP. For example IP base or IP Security, IP Voice don't support BGP. Service Provider or Advanced IP support BGP. 200 sites x $600 per IOS upgrade/purchase = $120,000. Most MPLS Service Provider will not support OSPF as a standard PE-CE routing protocol. If the service provider supports OSPF as PE-CE routing protocol, especially supports Sham-link, and the customer network doesn't require multi-homing, why not?
