PBR with mpls bgp send-label
mila008.is
I have problem with transition my network to mpls, PBR doesnt work after I enter the command BGP neighbour send-label.
my configs:
interface Vlanxxx
mtu 1560
ip address 1.1.1.1 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-mode
ip policy route-map PBR
load-interval 30
mpls bgp forwarding
mpls label protocol ldp
mpls ip
ip access-list extended PRIVATE-NETS-1
permit ip 10.0.0.0 0.255.255.255 2.2.2.2 0.0.1.255
permit ip 3.3.3.3 0.0.31.255 4.4.4.4 0.0.1.255
route-map PBR permit 25
match ip address PRIVATE-NETS-1
set ip next-hop 5.5.5.5
Anybody know this problem? Thx.
2 Accepted Solutions
Hi Elena,
there is not enough info to answer this question.
To which BGP neighbor do you send label? Is it reachable via which interface?
A blind guess would be that traffic received on the first vlan comes in labeled therefore cannot match the IP ACL.
But you need to tell us which type of traffic comes in, if IP or MPLS.
Cheers,
Riccardo
Hi Elena,
Policy based routing (PBR) is not supported for MPLS labeled traffic. The labels prevent the IP lookup to occur.
PBR is supported on VRF interfaces for the IP traffic that comes in through that interface. The support for this
started with CSCdu70318. Perhaps you could move the PBR to a preceeding router, where the traffic is still IP traffic
and not yet labeled?
Best regards,
Luc
7 Replies 7
Ivan Krimmel
Level 7
Level 7
Hi Elena,
pease add 'set mpls-label' statement under PBR route-map.
interface where this traffic should go not running mpls, traffic doesnt have mpls tags
interface Vlanxxx
ip address 5.5.5.6 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-mode
load-interval 30
end
nice catch, didn't noticed that.
Hi Elena,
Cheers,
Riccardo
mila008.is
mpls labels come in via interface
interface Vlanxxx
mtu 1560
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-mode
load-interval 30
mpls bgp forwarding
mpls ip
and interface
interface Vlanxxx
no ip redirects
no ip unreachables
no ip proxy-arp
ip pim sparse-mode
load-interval 30
end
doesnt run mpls
how i can change ip routing info with "IP" PBR in mpls-labeled traffic in this case?
Hi Elena,
Best regards,
Luc
Thanks for ur reply,  Luc
I think u r right, and i ll try to adapt my network for this feature
