Problem about using GE port on RSP720-3CXL-GE as MPLS uplink
kanmanee.k
I have a Problem about using a GE port on  Route Switch Processor 720 Model RSP720-3CXL-GE (Active Module) as MPLS uplink from the PE router to P Router and the L2VPN (xconnect point to point) are not working.
The whole VCs of l2vpn service on PE are DOWN. But the L3vpn(vrf) service is still working.
Can anyone tel me about the restriction of using the GE as MPLS uplink?
Thank you so much.
Kanmanee
Vinit Jain
Hello Kanmanee
Could you please share the configuration and show module output in a file. I presume you are having xconnect on a WAN card like ES+ or ES20.
Most likely it might not be supported to have the mpls interface on the RSP module for l2vpn but i will confirm after looking at the configuration. Also, please share the "sh mpls l2 vc <vcid> det" output
Vinit
--Vinit
Vinit Jain
Hello Kanmanee
Vinit
--Vinit
Hello Vinit
Thank you so much for your answer unfortunately I forgot to log the "sh mpls l2 vc <vcid> det" at the time problem occured. But the result were no mpls lables in the   "imposed label stack {}" and VC was down so the l2vpn services was not working.
Normally I use  WAN card like ES20 as uplinks. But on that day the WAN Card was broken. So I had to use GE port on the RSP card to be an uplink instead and only l2vpn service was down but l3vpn service was normal.
After that  my team replaced the new ES20 card and l2 service has came back.
How can I find the reference document that it might not be supported to have the mpls interface on the RSP module for l2vpn?
Thank you so much^-^
Kanmanee
P.S this Normal output
7609#sh mpls l2 vc 1181611816 de
Local interface: VFI xx_xxxx VFI up
  Interworking type is Ethernet
  Destination address: a.b.c.d VC ID: 1181611816, VC status: up
    Output interface: Gix/x/x, imposed label stack {16240 1996}
    Preferred path: not configured
    Default path: active
    Next hop: w.x.y.z
  Create time: 4d06h, last status change time: 3d17h
  Signaling protocol: LDP, peer a.b.c.d:0 up
    Targeted Hello: e.f.g.h (LDP Id) -> a.b.c.d, LDP is UP
    Status TLV support (local/remote)   : enabled/supported
      LDP route watch                   : enabled
      Label/status state machine        : established, LruRru
      Last local dataplane   status rcvd: No fault
      Last local SSS circuit status rcvd: No fault
      Last local SSS circuit status sent: No fault
      Last local  LDP TLV    status sent: No fault
      Last remote LDP TLV    status rcvd: No fault
      Last remote LDP ADJ    status rcvd: No fault
    MPLS VC labels: local 1001, remote 1996
    Group ID: local 0, remote 0
    MTU: local 1552, remote 1552
    Remote interface description: xxxxxxxxxxxxxxxxxxxxx
    MAC Withdraw: sent:0, received:1
  Sequencing: receive disabled, send disabled
  Control Word: On (configured: autosense)
  VC statistics:
    transit packet totals: receive 37, send 4971901
    transit byte totals:   receive 2220, send 6351078154
    transit packet drops:  receive 3, seq error 0, send 0
