Problem of L2VPN setup between Cisco3945 and Juniper J2320 (method l2circuit)
jerry.z.fan
I have to setup L2VPN between Cisco and Juniper routers. It is for the internal products testing in my company. But VC is always down there. I searched many documents, but didn't work. I really need help. Thank you..
Jerry FAN
J2320 is running on 11.4R5.5; Cisco3945 is running on 15.2(4)M2 with MPLS function activated.
root@Router_MPS_TEST_A# show
## Last changed: 2012-11-22 11:17:01 UTC
version 11.4R5.5;
system {
    host-name Router_MPS_TEST_A;
    root-authentication {
        encrypted-password "$1$xS88ja0F$cjZBwBjP6hIxrdGDEsE7r1"; ## SECRET-DATA
    services;
    syslog {
        user * {
            any emergency;
        file messages {
            any any;
            authorization info;
        file interactive-commands {
            interactive-commands any;
    license {
        autoupdate {
            url https://ae1.juniper.net/junos/key_retrieval;
interfaces {
    ge-0/0/0 {
        unit 0 {
            family inet {
                address 192.168.12.1/24;
            family mpls;
    ge-0/0/1 {
        vlan-tagging;
        encapsulation vlan-ccc;
        unit 0 {
            vlan-id 1;
        unit 121 {
            vlan-id 121;
    lo0 {
        unit 0 {
            family inet {
                address 1.1.1.1/32;
routing-options {
    static {
        route 2.2.2.2/32 next-hop 192.168.12.2;
protocols {
    mpls {
        interface ge-0/0/0.0;
        interface lo0.0;
    ldp {
        interface all;
    l2circuit {
        neighbor 2.2.2.2 {
            interface ge-0/0/1.121 {
                virtual-circuit-id 100;
                encapsulation-type ethernet-vlan;
                ignore-encapsulation-mismatch;
                ignore-mtu-mismatch;
security {
    policies {
        from-zone trust to-zone trust {
            policy default-permit {
                match {
                    source-address any;
                    destination-address any;
                    application any;
                then {
                    permit;
    zones {
        security-zone trust {
            tcp-rst;
            interfaces {
                ge-0/0/0.0 {
                    host-inbound-traffic {
                        system-services {
                            any-service;
                lo0.0 {
                        system-services {
                            any-service;
                ge-0/0/1.0 {
                        system-services {
                            any-service;
                ge-0/0/1.121 {
                        system-services {
                            any-service;
[edit]
Router_MPS_TEST_B#s run
Building configuration...
Current configuration : 1733 bytes
! Last configuration change at 06:22:03 UTC Thu Nov 22 2012
version 15.2
hostname Router_MPS_TEST_B
boot-start-marker
boot system flash0 c3900-universalk9-mz.SPA.152-4.M2.bin
boot-end-marker
enable password cisco
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
license udi pid C3900-SPE150/K9
redundancy
csdb tcp synwait-time 30
csdb tcp idle-time 3600
csdb tcp finwait-time 5
csdb tcp reassembly max-memory 1024
csdb tcp reassembly max-queue-length 16
csdb udp idle-time 30
csdb icmp idle-time 10
csdb session max-session 65535
interface Loopback0
 ip address 2.2.2.2 255.255.255.255
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
interface GigabitEthernet0/0
 ip address 192.168.12.2 255.255.255.0
 duplex auto
 speed auto
 mpls ip
interface GigabitEthernet0/1
 no ip address
 duplex auto
 speed auto
 no keepalive
interface GigabitEthernet0/1.121
 encapsulation dot1Q 121
 xconnect 1.1.1.1 100 encapsulation mpls
interface GigabitEthernet0/2
 no ip address
 shutdown
 duplex auto
 speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 1.1.1.1 255.255.255.255 192.168.12.1
control-plane
line con 0
 exec-timeout 0 0
 logging synchronous
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport input all
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 password cisco
 logging synchronous
 login
 transport input all
scheduler allocate 20000 1000
end
Router_MPS_TEST_B#
root@Router_MPS_TEST_A# run show l2circuit connections
Layer-2 Circuit Connections:
Legend for connection status (St)
EI -- encapsulation invalid      NP -- interface h/w not present
MM -- mtu mismatch               Dn -- down
EM -- encapsulation mismatch     VC-Dn -- Virtual circuit Down
CM -- control-word mismatch      Up -- operational
VM -- vlan id mismatch           CF -- Call admission control failure
OL -- no outgoing label          IB -- TDM incompatible bitrate
NC -- intf encaps not CCC/TCC    TM -- TDM misconfiguration
BK -- Backup Connection          ST -- Standby Connection
CB -- rcvd cell-bundle size bad  SP -- Static Pseudowire
LD -- local site signaled down   RS -- remote site standby
RD -- remote site signaled down  XX -- unknown
Legend for interface status
Up -- operational
Dn -- down
Neighbor: 2.2.2.2
    Interface                 Type  St     Time last up          # Up trans
    ge-0/0/1.121(vc 100)      rmt   NP
[edit]
root@Router_MPS_TEST_A# run show mpls interface detail
Interface: ge-0/0/0.0
  State: Up
  Administrative group: <none>
  Maximum labels: 3
  Static protection revert time: 5 seconds
  Always mark connection protection tlv: Disabled
  Switch away lsps : Disabled
[edit]
Router_MPS_TEST_B#sh mpls l2transport vc detail
Local interface: Gi0/1.121 up, line protocol up, Eth VLAN 121 up
  Destination address: 1.1.1.1, VC ID: 100, VC status: down
    Output interface: none, imposed label stack {}
    Preferred path: not configured
    Default path: no route
    No adjacency
  Create time: 04:35:05, last status change time: 03:31:50
  Signaling protocol: LDP, peer unknown
    Targeted Hello: 2.2.2.2(LDP Id) -> 1.1.1.1
    Status TLV support (local/remote)   : enabled/unknown (no remote binding)
      Label/status state machine        : local standby, AC-ready, LnuRnd
      Last local dataplane   status rcvd: no fault
      Last local SSS circuit status rcvd: no fault
      Last local SSS circuit status sent: not sent
      Last local  LDP TLV    status sent: not sent
      Last remote LDP TLV    status rcvd: unknown (no remote binding)
    MPLS VC labels: local 16, remote unassigned
    Group ID: local 0, remote unknown
    MTU: local 1500, remote unknown
    Remote interface description:
  Sequencing: receive disabled, send disabled
  VC statistics:
    packet totals: receive 0, send 0
    byte totals:   receive 0, send 0
    packet drops:  receive 0, seq error 0, send 0
Router_MPS_TEST_B#
shivjain
I could n't see mpls ip and mpls label protocol ldp command. Could you check it again. Also let us know what is the output of show mpls l2vpn citcuitid .....
I still remember by default Junipe doesn't peform PHP, that need to be enabled. Could you check that also.
regards
shivlu jain
www.mplsvpn.info
jerry.z.fan
Problem resolved. Changed forward-option to packet mode and add encapsulation vlan-ccc and vlan id on subinterface
in Junos as well.
hi
if possible could you highlight the changes you made or post the full configuration.
regards
shivlu jain
Here you go.
root@J2320> show configuration | no-more
## Last commit: 2012-11-27 10:44:17 UTC by root
version 11.4R5.5;
system {
    host-name J2320;
    services;
    syslog {
        user * {
            any emergency;
        file messages {
            any any;
            authorization info;
    license {
        autoupdate {
interfaces {
    ge-0/0/0 {
        unit 0 {
            family inet {
            family mpls;
    ge-0/0/1 {
        vlan-tagging;
        unit 0 {
            vlan-id 1;
        unit 512 {
            vlan-id 512;
    lo0 {
        unit 0 {
            family inet {
                address 1.1.1.1/32;
routing-options {
    static {
protocols {
    mpls {
        interface lo0.0;
    ldp {
        interface all;
    l2circuit {
        neighbor 2.2.2.2 {
            interface ge-0/0/1.512 {
security {
    forwarding-options {
        family {
            mpls {
                mode packet-based;
    zones {
            tcp-rst;
            interfaces {
                ge-0/0/0.0 {
                        system-services {
                            any-service;
                lo0.0 {
                        system-services {
                            any-service;
                ge-0/0/1.512 {
                        system-services {
                            any-service;
root@J2320>
root@J2320> show l2circuit connections extensive
Up -- operational
Dn -- down
Neighbor: 2.2.2.2
    ge-0/0/1.512(vc 100)      rmt   Up     Nov 27 10:50:26 2012           1
      Remote PE: 2.2.2.2, Negotiated control-word: Yes (Null)
      Incoming label: 299808, Outgoing label: 17
      Negotiated PW status TLV: No
      Local interface: ge-0/0/1.512, Status: Up, Encapsulation: VLAN
    Connection History:
        Nov 27 10:50:26 2012  status update timer
        Nov 27 10:50:26 2012  PE route changed
        Nov 27 10:50:26 2012  Out lbl Update                        17
        Nov 27 10:50:26 2012  In lbl Update                     299808
        Nov 27 10:50:26 2012  loc intf up                 ge-0/0/1.512
root@J2320>
Router_MPS_TEST_B#sh run
Current configuration : 1762 bytes
! Last configuration change at 10:04:06 UTC Tue Nov 27 2012
version 15.2
boot-start-marker
boot config flash0:/mpls.cfg
boot-end-marker
no aaa new-model
ip cef
no ip domain lookup
no ipv6 cef
redundancy
interface Loopback0
no ip address
shutdown
duplex auto
speed auto
mpls ip
no ip address
duplex auto
speed auto
no keepalive
interface GigabitEthernet0/1.512
encapsulation dot1Q 512
no ip address
shutdown
duplex auto
speed auto
no ip http server
control-plane
line con 0
exec-timeout 0 0
logging synchronous
line aux 0
line 2
no exec
transport input all
stopbits 1
line vty 0 4
password cisco
logging synchronous
login
transport input all
end
Router_MPS_TEST_B#
Local interface: Gi0/1.512 up, line protocol up, Eth VLAN 512 up
  Destination address: 1.1.1.1, VC ID: 100, VC status: up
    Output interface: Gi0/0, imposed label stack {299808}
    Default path: active
    Next hop: 192.168.12.1
  Create time: 00:31:23, last status change time: 00:02:02
  Signaling protocol: LDP, peer 1.1.1.1:0 up
    Status TLV support (local/remote)   : enabled/not supported
      Label/status state machine        : established, LruRru
      Last local SSS circuit status sent: no fault
      Last local  LDP TLV    status sent: no fault
      Last remote LDP TLV    status rcvd: not sent
    MPLS VC labels: local 17, remote 299808
    Group ID: local 0, remote 0
    MTU: local 1500, remote 1500
    Remote VLAN id: 512
  VC statistics:
    packet totals: receive 1010, send 1013
    byte totals:   receive 118856, send 141334
Router_MPS_TEST_B#
