Problem with BGP IPv4 Labeled-unicast on XR
Yahia CHARIF
Hi all,
In the topology bellow :
R1<------(ibgp ipv4 + label)------->XR1<-------(ebgp ipv4)------>R2
R1 and R2 are XE devices, XR1 is XR device.
I have iBGP IPv4 labled unicast between R1 and XR1 and eBGP ipv4 unicast between XR1 and R2.
The problem is that prefixes advertised by R2 to XR1 are note advertised via iBGP to R1.
when using XE instead of XR1 i see routes advertised correcly.
My question, is  it possible for routes received from a regular BGP address-family IPv4 unicast to be advertised again in BGP address-family IPv4 labled-unicast.
12 Replies 12
Julio E. Moisa
Hi Yahia,
Include the following line:
address-family ipv4 unicast
allocate-label all
Also once labeled is used you need to create a static route for the next hop IP, example:
XR1 (g0/0/0/0 10.0.0.1) ------- (g0/0 10.0.0.2) router 2
XR1 (xr os)
router static
10.0.0.2/32  g0/0/0/0
*Remember if you are creating an eBGP connection you need to configure a policy PASS to enable the communication between BGP routers
route-policy PASS
pass
exit
router bgp x
allocate-label all
neigh x.x.x.x
remote Y
address-family ipv4 labeled-unicast
route-policy PASS in
route-policy PASS out
Router 2
router bgp Y
neigh x.x.x.x remote X
neigh x.x.x.x send-label
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Hi Julio,
The "allocate-label all" command is already configured on XR1 and I see that works only for route localy generated and for routes received from other labled BGP Peer, but not for routes received from a regular bgp ipv4 unicast Peer.
With XE device no problem, labels are allocated to all received routes from both labled and unlabeled sessions.
Could you please provide the config of XR and R2? You should have something like:
XR Router
router static
route-policy PASS
pass
exit
router bgp x
allocate-label all
neigh x.x.x.x
remote Y
Router 2
router bgp Y
static route for /32 is already created, but I think it is for data-plane to work, in my situation the control-plane also not working.
rpl PASS in and out are there, and i see routes in bgp unicast table but not in labled-unicast.
=========== R1 ===========
router bgp 10
neighbor 10.0.0.2 remote-as 10
neighbor 10.0.0.2 update-source Loopback0
address-family ipv4
neighbor 10.0.0.2 activate
neighbor 10.0.0.2 send-community both
neighbor 10.0.0.2 send-label
exit-address-family
=========== XR1 ===========
router bgp 10
allocate-label all
neighbor 10.1.2.2
remote-as 20
neighbor 10.0.0.1
remote-as 10
next-hop-self
router static
10.1.2.2/32 GigabitEthernet0/0/0/3
route-policy PASS
  pass
end-policy
=========== R2 ===========
router bgp 20
neighbor 10.1.2.1 remote-as 10
address-family ipv4
network 10.10.10.0 mask 255.255.255.0
neighbor 10.1.2.1 activate
neighbor 10.1.2.1 send-community both
exit-address-family
Also I think, the /32 static route is not needed between XR1 and R2  because there is no labels between them.
Yes, that is correct, the static route is used for eBGP when label is configured and the allocate-label where the labeled is configured.
Why are you using label between R1 and XR1?
because in real topology, this XR1 is ASBR used for inter-as option C with other ASBR, and R1 is PE, so I need labled unicast session between them.
I tried to use both labled and unlabled bgp session between R1 and XR1 but it seemd to be not supported.
Hi Yahia,
If you are implementing Inter-AS Option C, I think the problem is between XR1 and R2, as I understand R2 is the PE (isp 2) and XR1 (isp 1) the address-family are inverse on XR1.
router bgp 10
allocate-label all
neighbor 10.1.2.2
remote-as 20
address-family ipv4 labeled-unicast    <--- add the labeled unicast.
neighbor 10.0.0.1
remote-as 10
address-family ipv4 labeled-unicast   <---- remove it and set up normal AF ipv4.
next-hop-self
router static
route-policy PASS
  pass
end-policy
router bgp 20
address-family ipv4
neighbor 10.1.2.1 send-label  <--- add it
exit-address-family
Hi Julio,
Thanks for your efforts.
XR1 is connected to another ASBR let's say R3 for Inter-as option C. with R2 is just a normal AF IPv4. the topology is like this:
R1-----------XR1-----------R2
R3
But i think it is better to focus just on the first topology:
R1------(iBGP+label)-----XR1------(eBGP)-----R2
Need routes coming from R2 (unlabeled) to be advertised with labels to R1.
Hello Yahia,
Did you get any answers for your question ?
Thiru
Hello, did you ever get a resolution to this, I am having the exact same issue but in a CSC configuration, my topology looks like this. In this particular scenario, The Carrier Customer(ISPB) is not running VPNv4, only unicast routes, the use of LDP in the ISPB network is only from transport intra-as LDP path: ISPB-PE1[XE] -- ISPB-P[XE](RouteReflector) -- ISPB-CSC-CE[XR] & ISPB-CSC-CE[XE] -- ISPB-P[XE] -- ISPB-PE[XR].
Topology:
CE1-SRC[XE] -- ISPB-PE1[XE] -- ISPB-P[XE](RouteReflector) -- ISPB-CSC-CE[XR] -- ISPA-CSC-PE[XE] -- ISPA-P[XE] -- ISPA-CSC-PE[XR] -- ISPB-CSC-CE[XE] -- ISPB-P[XE] -- ISPB-PE[XR] -- CE1-DEST[XE]
The only way I could get the control plane to forward prefixes from CE1-DEST to CE1-SRC is to configure a Labeled-Unicast session with IPSB-PE. When I use a normal unicast session, the prefixes from CE1-DEST are not propagated by ISPB-PE.
KevA
I have a similar situation in a simulated but might have resolved. I followed Julio Moisa configurations instructions but I also included the ipv4 address-family for the same neighbor on the XR. The router will bark that it ipv4 unicast and ipv4 labeled-unicast are not support but it will still accept. I also made sure I configured an access-list on my XR router and a prefix list on the XE routers to all the labels for the prefixes being advertised. Also, i noticed if removed ipv4-address family from the bgp configuration on the XR, then it breaks the vpnv4 neighborship between my route reflectors in the ISPs.
router bgp 67890
network 10.10.74.3/32
network 10.10.74.4/32
network 10.10.74.5/32
allocate-label all
address-family vpnv4 unicast
neighbor 10.11.4.1
remote-as 12345
XE router:
router bgp 12345
address-family ipv4
neighbor 10.11.4.2 activate
neighbor 10.11.4.2 send-label
XR MPLS Routers
ipv4 access-list 1
10 permit ipv4 host 10.10.74.1 any
20 permit ipv4 host 10.10.74.2 any
30 permit ipv4 host 10.10.74.3 any
40 permit ipv4 host 10.10.74.4 any
50 permit ipv4 host 10.10.74.5 any
60 permit ipv4 host 10.10.72.1 any
70 permit ipv4 host 10.10.72.2 any
80 permit ipv4 host 10.10.72.3 any
90 permit ipv4 host 10.10.72.4 any
100 permit ipv4 host 10.10.72.5 any
mpls ldp
router-id 10.10.74.1
address-family ipv4
label
local
allocate for 1
XE mpls routers:
mpls ldp label
allocate global prefix-list LABELS
ip prefix-list LABELS seq 5 permit 10.10.72.2/32
ip prefix-list LABELS seq 10 permit 10.10.72.3/32
ip prefix-list LABELS seq 15 permit 10.10.72.4/32
ip prefix-list LABELS seq 20 permit 10.10.72.1/32
ip prefix-list LABELS seq 25 permit 10.10.72.5/32
ip prefix-list LABELS seq 30 permit 10.10.74.3/32
ip prefix-list LABELS seq 35 permit 10.10.74.4/32
ip prefix-list LABELS seq 40 permit 10.10.74.5/32
ip prefix-list LABELS seq 45 permit 10.10.74.1/32
ip prefix-list LABELS seq 50 permit 10.10.74.2/32
