problems with import map
h.saberwal
Community Member
Hi there,
I am trying to apply the following configuration:
ip vrf AA_BB
rd 1:100010
import map RZ-TAG-OUT
export map RZ-TAG-IN
router bgp 11
address-family ipv4 vrf AA_BB
neighbor 192.168.3.2 remote-as 64810
neighbor 192.168.3.2 activate
neighbor 192.168.3.2 next-hop-self
neighbor 192.168.3.2 send-community
no auto-summary
no synchronization
exit-address-family
ip extcommunity-list standard R_SERVER permit rt 1:110001
route-map RZ-TAG-OUT permit 10
match extcommunity R_SERVER
set community 64101:3000
Now this does not seem to want to work, i do not see anything imported, yet when a do a straight forward import rt 1:110001 then that imports lots of routes in the AA_BB vrf
not sure if my syntax is wrong or understanding or what?
thanks
The import map feature will only work on route-targets that have been configured. The import map is used to further filter the prefixes that would normally be imported.
Try adding "route-target import 1:110001" under ip vrf AA_BB.
Hope this helps,
Hope this helps,
Thanks a lot!! i had tried this before but i had other issues on the network and hence did not spot it working!. I think the cisco documentation needs to be changed to reflect this! I went through all the cisco command references as i thought that this was the case but no document supported it and hence i did not use it.
Once again thanks a lot!
