Reg :Connection to MPLS N/W
cisco.anubhav
Kindly help me in getting my network connected to an MPLS network of our service provider.We are using static routing in our network and one MPLS link is to be connected through gigabit port,kindly suggest what configuration is to be done on my router so that we may connect successfully to MPLS n/w.
yashfaqu
Normally you dont need to configure any thing to join MPLS Network, all the configurations will be done by SP.
All you need to do is configure IP address, and routing protocol.
