Routing between same VRF instance on different PE routers
Martorossi
Consider this topology
R4(g0/1)----------(g0/0)R1(g0/1)----------(g0/2)R2(g0/3)----------(g0/1)R3(g0/0)----------(g0/1)R5
        Provider Network
R1(g0/0)-belongs to Vrf 101:ACME(ip vrf forwarding 101:ACME)-172.16.101.1
R3(g0/0)-belongs to Vrf 101:ACME(ip vrf forwarding 101:ACME)-192.168.202.1
R1-Provider Edge 1 R2-Provider R3-Provider Edge 2 R4-Customer Edge 1 R5-Customer Edge 2
IP Addresses
All interfaces use a subnet mask of 255.255.255.0(/24)
R4 (g0/1)-172.16.101.2 R1 (g0/0)-172.16.101.1 R1 (g0/1)-10.23.0.1 R2 (g0/2)-10.23.0.2
R2 (g0/3)-10.34.0.2 R3(g0/1)-10.34.0.3 R3(g0/0)-192.168.202.1 R5(g0/1)-192.168.202.2
Configuration
R1
Ip vrf 101:ACME
rd 1.1.1.1:1
address-family ipv4
route-target export 1.1.1.1:101
route-target import 3.3.3.3:101
R3
Ip vrf 101:ACME
rd 3.3.3.3:1
address-family ipv4
route-target export 3.3.3.3:101
route-target import 1.1.1.1:101
Ospf process id 1 is configured for interfaces on R1(g0/1),R2(g0/2),R2(g0/3), R3(g0/1) hence R1 can ping R3(g0/1)-10.34.0.3
R1#ping vrf 101:ACME 172.16.101.1 successful
R1#ping vrf 101:ACME 192.168.202.1 (not successful)
What can be done about the configuration to enable R1 ping R3(g0/0)-192.168.202.1 successfully
9 Replies 9
Nagendra Kumar Nainar
You have to enable MP-BGP with VPNv4 address family enabled on R1 and R3 and redisribute the vrf prefix into BGP.
Below link will be helpful:
http://www.cisco.com/c/en/us/support/docs/multiprotocol-label-switching-mpls/mpls/13733-mpls-vpn-basic.html
I am still having problem with the ping
What I did
I created Loopback 0 of 1.1.1.1 on R1,3.3.3.3 on R3 and advertised it under router ospf 1
Router 1
Router ospf 101 vrf 101:ACME
network 172.16.101.0 0.0.0.255 area 0
redistribute bgp 64512 subnets
Router bgp 64512
neighbor 3.3.3.3 remote as 64512
neighbor 3.3.3.3 update-source Loopback 0
address-family vpnv4
neighbor 3.3.3.3 activate
neighbour 3.3.3.3 send-community extended
address-family ipv4 vrf 101:ACME
redistribute ospf 101 vrf 101:ACME
Router 3
Network 192.168.202.0 0.0.0.255 area 0
Redistribute 64512 subnets
Router bgp 64512
neighbor 1.1.1.1 remote as 64512
neighbor 1.1.1.1 update-source Loopback 0
neighbor 1.1.1.1 activate
neighbour 1.1.1.1 send-community extended
The Bgp neighborship between R1(1.1.1.1) and R3(3.3.3.3) is up and ok.
Do you see those prefixes advertised by BGP to neighbor?. Do you see if it is installed in vrf routing table?.
Can you check "show ip bgp vpnv4 all" on both the PE devices and "show ip route vrf <vrf-name>" and see if it is populated?.
Just to add, I hope you have MPLS enabled on all core facing interfaces on PE and P routers.
This is the output
R1#show ip route vrf 101:ACME
      172.16.0.0/16 is variably subnetted, 2 subnets, 2 masks
C        172.16.101.0/24 is directly connected, FastEthernet1/0
L        172.16.101.1/32 is directly connected, FastEthernet1/0
B     192.168.202.0/24 [200/0] via 3.3.3.3, 01:45:09
R1#
R3#show ip route vrf 101:ACME
      172.16.0.0/24 is subnetted, 1 subnets
B        172.16.101.0 [200/0] via 1.1.1.1, 01:47:08
      192.168.202.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.202.0/24 is directly connected, FastEthernet1/1
L        192.168.202.1/32 is directly connected, FastEthernet1/1
R3#
R1#show ip bgp vpnv4 all
   Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 1.1.1.1:1 (default for vrf 101:ACME)
*> 172.16.101.0/24  0.0.0.0                  0         32768 ?
*>i192.168.202.0    3.3.3.3                  0    100      0 ?
Route Distinguisher: 3.3.3.3:1
R1#
R3#show ip bgp vpnv4 all
*>i172.16.101.0/24  1.1.1.1                  0    100      0 ?
Route Distinguisher: 3.3.3.3:1 (default for vrf 101:ACME)
*> 192.168.202.0    0.0.0.0                  0         32768 ?
R3#
Mpls is enabled on R1,R2 and R3 specifically R1(g0/1),R2(g0/2),R2(g0/3) and R3(g0/1), as for my output interfaces they are different from the gigabitethernet interfaces because I used fastethernet interfaces on GNS3. I enabled Mpls globally on R1,R2 and R3 with Mpls ip command.
R1-MPLS label range 100 199,R1(g0/1)-Mpls ip
R2-MPLS label range 200 299,R2(g0/2),R2(g0/3)-Mpls ip
R3-MPLS label range 300 399, R3(g0/1)-Mpls ip
Did not resolve the ping issue of
Do you have MPLS enabled on the core interfaces?. Can you check "show ip cef vrf <> <prefix>" and see if proper labels are imposed?.
Get "show mpls forwarding" as well
R1#show ip cef vrf 101:ACME
Prefix               Next Hop             Interface
0.0.0.0/0            no route
0.0.0.0/8            drop
0.0.0.0/32          receive
127.0.0.0/8        drop
172.16.101.0/24      attached             FastEthernet1/0
172.16.101.0/32      receive                FastEthernet1/0
172.16.101.1/32      receive                FastEthernet1/0
172.16.101.2/32      attached              FastEthernet1/0
172.16.101.255/32 receive                 FastEthernet1/0
192.168.202.0/24     10.23.0.2           FastEthernet1/1
224.0.0.0/4          drop
224.0.0.0/24       receive
240.0.0.0/4          drop
255.255.255.255/32   receive
R3#show ip cef vrf 101:ACME
0.0.0.0/0            no route
0.0.0.0/8            drop
0.0.0.0/32          receive
127.0.0.0/8        drop
172.16.101.0/24      10.34.0.2            FastEthernet1/0
192.168.202.0/24     attached            FastEthernet1/1
192.168.202.0/32     receive               FastEthernet1/1
192.168.202.1/32     receive               FastEthernet1/1
192.168.202.2/32     attached             FastEthernet1/1
192.168.202.255/32 receive               FastEthernet1/1
224.0.0.0/4          drop
240.0.0.0/4          drop
R1#show mpls forwarding-table
Local      Outgoing   Prefix           Bytes Label   Outgoing   Next Hop
Label      Label      or Tunnel Id     Switched      interface
16         No Label   172.16.101.0/24[V]   \
                                       0             aggregate/101:ACME
100        No Label      2.2.2.2/32        0           Fa1/1      10.23.0.2
101        201               3.3.3.3/32       0           Fa1/1      10.23.0.2
102        Pop Label    10.34.0.0/24   0            Fa1/1      10.23.0.2
R3#show mpls forwarding-table
16         No Label   192.168.202.0/24[V]   \
300        200             1.1.1.1/32         0            Fa1/0      10.34.0.2
301        No Label     2.2.2.2/32         0            Fa1/0      10.34.0.2
302        Pop Label  10.23.0.0/24    0             Fa1/0      10.34.0.2
It seems the labels are assigned and exchanged. Can you check the below:
1. On R1, check "show ip cef vrf 101:ACME 192.168.202.0 255.255.255.0" and see if it pushes labels {16, 201}
2. On R3, check "show ip cef vrf 101:ACME 172.16.101.0 255.255.255.0" and see if pushes labels {16, 200}.
Also try "ping mpls ipv4 1.1.1.1 255.255.255.255" from R3 and "ping mpls ipv4 3.3.3.3 255.255.255.255" from R1.
-Nagendra
I have concluded on the issue, It should be an IOS problem because the route of 192.168.202.0/24 is in the vrf routing table 101:ACME(show ip route vrf 101:ACME) as a bgp learned route in R1.
