Segment routing's anycast sid on XRV9k and XE
sachin30720041
I have the following setup. And  I have configured anycast sid on CSR2 and XR3. I have configured a policy in XRV4 with endpoint 1.1.1.1.
                    CSR2
CSR1                       XRV4
               XR3
1.1.1.1 is loopback on CSR1. And I have included 'anycast-sid-inclusion' command in the policy.
segment-routing
traffic-eng
policy pol1
source-address ipv4 4.4.4.4
color 123 end-point ipv4 1.1.1.1
candidate-paths
preference 100
dynamic
exit
But I do not see anycast sid in the path of policy pol1.
Below is the output of 'show segment-routing traffic-eng policy name srte_c_123_ep_1.1.1.1'.
XRV4#show segment-routing traffic-eng policy name srte_c_123_ep_1.1.1.1
SR-TE policy database
Color: 123, End-point: 1.1.1.1
Status:
Admin: up Operational: up for 00:31:35 (since Jul 27 00:0 7:26.625)
Candidate-paths:
Preference: 100 (configuration) (active)
Requested BSID: dynamic
Maximum SID Depth: 10
Anycast Inclusion: Enabled
Dynamic (valid)
Metric Type: TE, Path Accumulated Metric: 20
24005 [Adjacency-SID, 100.20.40.4 - 100.20.40.2]
16001 [Prefix-SID, 1.1.1.1]
What is the equivalent of 'anycast-sid-inclusion' on Cisco CSR router ?
CSR1
segment-routing mpls
connected-prefix-sid-map
address-family ipv4
1.1.1.1/32 index 1 range 1
exit
int gi1
ip address 100.10.20.1 255.255.255.0
ip router isis 1
isis network point-to-point
no sh
int gi2
ip address 100.10.30.1 255.255.255.0
ip router isis 1
no sh
int lo0
ip address 1.1.1.1 255.255.255.255
ip router isis 1
exit
router isis 1
is-type level-1
net 49.0001.1111.1111.1111.00
router-id lo0
metric-style wide
distribute link-state
mpls traffic-eng router-id lo0
mpls traffic-eng level-1
exit
CSR2
address-family ipv4
2.2.2.2/32 index 2 range 1
23.23.23.23/32 index 23 range 1
exit
int gi1
ip address 100.10.20.2 255.255.255.0
ip router isis 1
no sh
int gi2
ip address 100.20.40.2 255.255.255.0
ip router isis 1
no sh
int lo0
ip address 2.2.2.2 255.255.255.255
exit
int lo1
ip address 23.23.23.23 255.255.255.255
ip router isis 1
isis prefix n-flag-clear
exit
router isis 1
is-type level-1
net 49.0001.2222.2222.2222.00
router-id lo0
metric-style wide
exit
XR3
int gi0/0/0/0
ip address 100.30.40.3 255.255.255.0
no sh
int gi0/0/0/2
ip address 100.10.30.3 255.255.255.0
no sh
int lo0
ip address 3.3.3.3 255.255.255.255
exit
int lo1
exit
router isis 1
is-type level-1
net 49.0001.3333.3333.3333.00
address-family ipv4 unicast
metric-style wide
router-id lo0
exit
int gi0/0/0/0
point-to-point
exit
int gi0/0/0/2
point-to-point
exit
int lo1
prefix-sid index 23
exit
XR4
segment-routing
traffic-eng
policy pol1
candidate-paths
preference 100
dynamic
exit
root
int gi0/0/0/0
ip address 100.30.40.4 255.255.255.0
no sh
int gi0/0/0/2
ip address 100.20.40.4 255.255.255.0
no sh
int lo0
ip address 4.4.4.4 255.255.255.255
exit
router isis 1
is-type level-1
net 49.0001.4444.4444.4444.00
metric-style wide
router-id lo0
exit
int gi0/0/0/0
point-to-point
exit
int gi0/0/0/2
point-to-point
exit
int lo0
prefix-sid index 4
exit
Sachin
4 Accepted Solutions
Harold Ritter
Hi @sachin30720041 ,
The anycast config is incomplete on CSR2 and XRV3. You nee to advertised the prefix-sid for the  lo0 interface and additionally the anycast prefix-sid with the n flag cleared for lo1 (anycast loopback interface).
On CSR2, you are missing the following:
int lo0
ip router isis 1
On XRV3, you are missing the following:
router isis 1
int lo0
prefix-sid index 3
Int lo1
prefix-sid index 23 n-flag-clear
This is normal behavior, given that XRV4 is directly connected to both XRV3 and CSR2, which explains why this anycast sid is not being used, just the same as the node sid would not be used in tis context.
Also, bear in mind that traffic to 1.1.1.1 would not be forwarded using the policy by default. You would need to use "autoroute" under the policy to make sure traffic to 1.1.1.1 is steered through the policy.
segment-routing
traffic-eng
policy pol1
autoroute
include ipv4 1.1.1.1/32
This is currently not supported on the CSR1k. It is on the roadmap though.
6 Replies 6
Harold Ritter
int lo0
ip router isis 1
router isis 1
int lo0
prefix-sid index 3
Int lo1
Hello Harold,
Thanks for the reply.
I made the changes but when I ping from XR4 to CSR1 I see only MPLS LABEL 16001 in the packet. I do not see 16023 in the packet. If anycast is working correctly then there should 16023 and 16001 in the packet. Correct ?
RP/0/RP0/CPU0:XR4#traceroute 1.1.1.1 source 4.4.4.4
Wed Jul 27 19:04:55.760 UTC
Tracing the route to 1.1.1.1
1 100.20.40.2 [MPLS: Label 16001 Exp 0] 57 msec 9 msec 8 msec
2 100.10.30.1 55 msec
100.10.20.1 45 msec *
segment-routing
traffic-eng
policy pol1
autoroute
Sachin
