Sham Link Lab | downbit not being set correctly
So, in an effort build a sham link lab setup I have the following setup:
PE1 ----- CE1 running OSPF in VRF VPN_A
PE2 ----- CE2 running OSPF in VRF VPN_A
PE1 is IOS
PE2 is XR
There is a backdoor link from CE1 to CE2.
PE1 and PE2 have a BPG vpnv4 connection to each other. MPLS and LDP running across core. OSPF is redistributing into BPG and vice versa on both PE1 and PE2.
Classic sham link lab.
Before I create the same link, I create loopback 1 (10.2.2.2/32) on PE1 and then use the network command under BGP to get it into the BGP.
I do NOT enable OSPF on the loopback. I need PE2 to see the best path to loopback1 over the MPLS superbackbone NOT over the OSPF connection to CE2.
Now that I think SHOULD happen once I enter the network command is as follows:
  • OSPF sees 10.2.2.2/32 in BGP and redistributes it as a type 5 AND SETS THE DOWN BIT.
  • The LSA is flooded throughout the OSPF domain and PE2 gets it.
  • It does not redistribute back into BGP because the down bit it set.
But if I look on PE1 I can see the down bit is not being set...
CONFIG:
PE1#sh run | sec router bgp
router bgp 100
bgp router-id 2.2.2.2
bgp log-neighbor-changes
no bgp default ipv4-unicast
neighbor 19.19.19.19 remote-as 100
neighbor 19.19.19.19 update-source Loopback0
address-family ipv4
exit-address-family
address-family vpnv4
neighbor 19.19.19.19 activate
neighbor 19.19.19.19 send-community extended
exit-address-family
address-family ipv4 vrf VPN_A
network 10.2.2.2 mask 255.255.255.255
redistribute ospf 100
exit-address-family
PE1#sh run int lo1
Building configuration...
Current configuration : 118 bytes
interface Loopback1
description sham-link loopback
vrf forwarding VPN_A
ip address 10.2.2.2 255.255.255.255
end
PE1#sh run | sec router ospf 100
router ospf 100 vrf VPN_A
router-id 22.22.22.22
area 0 authentication message-digest
redistribute bgp 100 subnets
PE1#
OUTPUT:
PE1#sh ip ospf 100 database external 10.2.2.2
OSPF Router with ID (22.22.22.22) (Process ID 100)
Type-5 AS External Link States
LS age: 861
Options: (No TOS-capability, DC, Upward)
LS Type: AS External Link
Link State ID: 10.2.2.2 (External Network Number ) <<<<<<<<<<<< locally redistributed, ready to be sent to PE1, but down bit is not set
Advertising Router: 22.22.22.22
LS Seq Number: 80000002
Checksum: 0x17FD
Length: 36
Network Mask: /32
Metric Type: 2 (Larger than any link state path)
MTID: 0
Metric: 1
Forward Address: 0.0.0.0
External Route Tag: 3489661028
LS age: 2701
Options: (No TOS-capability, DC, Downward) <<<<<<<< THIS IS PE2 (19.19.19.19) redistributing its VPNv4 BGP route back into OSPF and correctly setting down bit.
Advertising Router: 119.119.119.119
LS Seq Number: 80000001
Checksum: 0x28E7
Length: 36
Network Mask: /32
MTID: 0
Metric: 1
PE1#
According to https://tools.ietf.org/html/rfc4576 section 4 "When a type 3, 5, or 7 LSA is sent from a PE to a CE, the DN bit MUST be set.".
Can anyone advise why this isn't happening?
Network Engineer
CCIE SP #69245
filopeter
There is a nice document which describes loop-prevention techniques when running ospf on ce-pe link.
https://www.cisco.com/c/en/us/support/docs/ip/open-shortest-path-first-ospf/118800-configure-ospf-00.html
In this document you can find the following note:
MPLS VPN OSPF PE-CE always includes the loop-prevention mechanism in order to handle issues. In the older Cisco IOS, the Per original IETF draft Type 3 LSAs use the DN Bit in LSA and Type 5 LSAs use a tag. The newer RFC 4576 mandates use of DN Bit for both Type 3 and Type 5 LSAs.
This was committed via Cisco bug ID CSCtw79182.
The PE routers with Cisco IOS images with the fix of this defect will originate Type 5 external LSAs with both DN Bit and a tag as loop-prevention mechanisms. Previous Cisco IOS versions advertised the only tag for this purpose for External Routes.
I hope this helps,
P.
Hi Peter,
Thanks for the response.
I think my problem might be related to https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvs74549/?rfs=iqvred
I'm running IOS-XE version Version 16.6.5, which is covered under this bug. I'll test this in a lab and report back.
For now, if I simply apply a route-map on the redistribution of BGP to OSPF to block the loopbacks, then the sham link works fine.
Network Engineer
CCIE SP #69245
I might be completely missing the point here but... have you configured the actual sham-link between src/dst loopback under OSPF?  I think that's what you're missing.
See: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/iproute_ospf/configuration/15-sy/iro-15-sy-book/iro-sham-link.html
Sorry perhaps my discussion is misnamed, my concern is not regarding the actual sham-link itself. Its about the down bit not being set (which is a check I performed before configuring the sham-link). If I use route-maps to filter the loopbacks entering the LSDB it works fine.
Network Engineer
CCIE SP #69245
