SNMP monitoring for EoMPLS virtual circuit
vital-group
I am looking to implement SNMP-based monitoring of an MPLS layer-2 tunnel. The desired result would be the same as the output from the following command:
"sh mpls l2transport vc"
I have configured the router to generate SNMP traps based on LDP changes, but this is not specific to the status of the EoMPLS tunnel.
Thanks in advance.
7 Replies 7
swaroop.potdar
Level 7
Level 7
Polling to these MIB values would have your task accomplished.
1) VC status <--> cpwVcOperStatus
2) If you need outbound staus <--> pwVcInboundOperStatus
3) Inbound status <--> cpwVcOutboundOperStatus
And here is the link for list of MIB objects for L2VPN.
http://www.cisco.com/en/US/products/ps6441/products_configuration_guide_chapter09186a00808194e1.html
HTH-Cheers,
Swaroop
Swaroop,
Thanks for the info. This works great on 12.4 and 12.2SB. I forgot to mention that I'm actually looking for a solution for CAT 6500 + Supervisor 720 running 12.2SX. I don't think these particular MIB values exist on this platform :(
Any ideas?
ftp://ftp.cisco.com/pub/mibs/v2/CISCO-IETF-PW-MIB.my
Here is a link for the MIB supported in 7600/6500. And this covers the MIB for PW status as well.
Use the IOS 12.2SR. And I believe your task would be accomplished.
Please let me know if I could be of any more help.
HTH-Cheers,
Swaroop
HTH-Cheers,
Swaroop
The Supervisor 720 on 7600 will run 12.2SR, but unfortunately I have a 6500 chassis.
Swaroop,
Unfortunately it seems the 6500 will only run 12.2SX. According to the Cisco IOS MIB locator this does not support the CISCO-IETF-PW-MIB.
I am quite surpised, since this is supposed to be Cisco's flagship multilayer switch.
Thanks for your help. Please let me know if you have any other suggestions.
I am not sure of you post, as the IOS compatibilty is with the supervisor.
And since you have a Sup720, this supervisor is compatible with 12.2SR as well.
Chassis wont matter.
Let me know if you have any more questions.
HTH-Cheers,
Swaroop
Yes, thats funny and true..SUP-720 on 6500 doesnt support 12.2SR as per SW Advisor.
I dont think there is any technical limitation to do so. But it probably is a internal business limitation.
The BU which own up SR is different from the BU who was working on till SX, hence the stark contrast.
HTH-Cheers,
Swaroop
