Stable Code for 7200
NAVIN PARWAL
Level 7
Level 7
Folks,
Could someone recommend a stable code for the 7200 series router which supports SSH with the source interface option.
swaroop.potdar
Level 11
Level 11
Its a very open question.
What may be stable for one may not be stable for others, depending on the features being used.
A through BUG scrub needs to be done based on the features being impemented by you.
HTH-Cheers,
Swaroop
ksolie
Level 2
Level 2
I the lab, I've tested 12.2.28SB2 and it seems pretty stable.
Cisco gave us a big presentation, and this seemed to be the code of choice.
I'm doing a large rollout for a customer, and using this is the code set we are going with. Of course check the bugs and stuff if you have the time.
hi all and parwal,
if you come across a stable IOS after you also test it internally, please post it here.
Thanks.
JC
