Strange problem with BGP over MPLS
nagesh
hi.
We have an MPLS link between cityA & cityB
BGP is configured to advertise the connected network on both the routers.
I can see the routes(LAN IP Block) of CityA on CityB router but on cityA router there is only one BGP route which is of the WAN IP,
Please suggest the fix for the same
Thanks in advance.
mounir.mohamed
Level 7
Level 7
Hi Negesh,
As far as i understand your LAN network missing from CityA side.
First of all we need to check if the network begins received but not selected or doesn't received at all.
So kindly provide the output of
CityA-Router#Show ip bgp summary
If the network received but not selected we can go further and troubleshoot it, but if it's doesn't received you have to open a case with your Service Provider regarding that.
Please rate helpful posts.
Best Regards,
Mounir Mohamed
