TE PROBLEM
shivlu jain
Level 9
Level 9
please let me know if we are having two paths in the igp primary cost is 40 and secondary cosct is 80.
but when i create 2 tunnels one for primary and one for secondary at that time my load balancing occurs in both tunnels with cost of 41.
As i know TE will take the igp cosct but it happens in this case.
regards
shivlu
kewlnetguy
Community Member
Hi Shivlu,
Is it possible to share the TE configuration used. Please note that in case TE tunnels are created for same destination the primary available path will be used while autoroute is used and it will provide the cost " Local to router ".
Alternatively you can use explicit path or static routing as welll
Cheers!
Prince
