TE tunnel trouble
ngoldfinger
I have an EoMPLS tunnel running ok
Then I created a TE tunnel its up and running
Now I want to assign incoming traffic fr a given VLAN to that TE Tunnel, so I added in the xconnect the pseudowire class:
xconnect x.x.x.x VCID encapsulation MPLS pw-class pwname
My problem is im not sure if traffic is passing through the TE tunnel,
How can I verify this?
How can I configure max BW for that TE tunnel?
Sincerely,
Nicolas
Harold Ritter
You can make sure that the loopback address of the PE terminating the EoMPLS is reachable via the Tunnel interface by using the "autoroute announce" feature.
Hope this helps,
This can be done by Tunnel selection feature also which is available in 12.0(27) wherein you can map the AToM vc's to a particular TE tunnel.
pseudowire-class pw1
encapsulation mpls
preferred-path interface Tunnel1
Hope this helps.
