TE tunnel with dynamic path
olorunloba
Level 10
Level 10
I configured an MPLS TE tunnel, it stays down, giving the following error
R4#sh mpls traffic-eng tunnels tun 0
Name: R4_t0 (Tunnel0) Destination: 100.1.44.1
Status:
Admin: up Oper: down Path: not valid Signalling: Down
path option 1, type dynamic
Config Parameters:
Bandwidth: 500 kbps (Global) Priority: 0 0 Affinity: 0x0/0xFFFF
Metric Type: TE (default)
AutoRoute: disabled LockDown: disabled Loadshare: 500 bw-based
auto-bw: disabled
Shortest Unconstrained Path Info:
Path Weight: 1562 (TE)
Explicit Route: 100.1.77.5 100.1.77.1 100.1.44.1
History:
Tunnel:
Time since created: 16 minutes, 46 seconds
Time since path change: 13 seconds
Prior LSP:
ID: path option 1 [32]
Removal Trigger: path option updated
Last Error: PCALC:: No path to destination, 100.1.44.11
R4#
When I change to a specific explicit path, it comes up
Status:
Admin: up Oper: up Path: valid Signalling: connected
path option 1, type explicit test (Basis for Setup, path weight 1562)
Config Parameters:
auto-bw: disabled
InLabel : -
OutLabel : Serial0/0.2, 17
RSVP Signalling Info:
Src 100.1.44.4, Dst 100.1.44.1, Tun_Id 0, Tun_Instance 39
RSVP Path Info:
My Address: 100.1.44.4
Record Route: NONE
Tspec: ave rate=500 kbits, burst=1000 bytes, peak rate=500 kbits
RSVP Resv Info:
Record Route: NONE
Fspec: ave rate=500 kbits, burst=1000 bytes, peak rate=500 kbits
History:
Tunnel:
Time since created: 18 minutes, 4 seconds
Time since path change: 7 seconds
Current LSP:
Uptime: 7 seconds
Prior LSP:
R4#
Find below the config of the tunnel. Is there something I'm doing wrong?
interface Tunnel0
ip unnumbered Loopback0
tunnel destination 100.1.44.1
tunnel mode mpls traffic-eng
tunnel mpls traffic-eng priority 0 0
tunnel mpls traffic-eng bandwidth 500
tunnel mpls traffic-eng path-option 1 explicit name test
end
7 Replies 7
attrgautam
Level 10
Level 10
I knnow it may sound silly. But did you give
tunnel mpls traffic-eng path-option 2 dynamic
under the TE tunnel
Regds
I didn't. I was testing in a lab environment and wanted to know why the dynamic option did not work. I feel that the dynamic path should be able to find a path even if there is only to setup the tunnel.
And it does not sound silly to me.
Sorry to barge in again , is the issue resolved ?
Well, like I said, it is a lab scenario, I will have to recreate it. But I'm wondering what the problem could have been?
If you have the same constraints for the dynamic path-option as for the explicit one, there is no reason for the tunnel not to come up as the dynamic path-option is less restrictive.
The command "sh mpls traffic-eng topology path destination " should tell you whether the tunnel would come up or not.
Hope this helps,
I found out what the problem was, not enough bandwidth on the physical interface to accomodate the TE.
What I now wonder is the reason the TE came up with a path explicitly stated? Should the bandwidth constraint not apply to it also.
Harold, please kindly explain the output of the command you gave in your post.
The tunnel with explicit path-option should have had the same issue as with the dynamic path-option.
The command I recommended tells you if a tunnel could be establish and what the path would be.
Hope this helps,
