10-24-2005 04:22 AM
A Chairde,
Am having problems setting up MPLS between a AS5350 and 7609 , I have used commands stated in this link, enable MPLS incrementally on a network.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios121/121cgcr/switch_c/xcprt4/xcdtagc.pdf
The commands below are added to each router, and some troubleshooting.
7609
ip cef distributed
interface Loopback0
ip address 192.168.254.1 255.255.255.255
tag-switching advertise-tags
interface GigabitEthernet3/12
ip address 192.168.230.162 255.255.255.248
mpls label protocol tdp
tag-switching ip
AS5350
ip cef
interface Loopback0
ip address 192.168.254.2 255.255.255.255
interface FastEthernet0/0
ip address 192.168.230.161 255.255.255.248
duplex auto
speed auto
mpls ip
h323-gateway voip interface
h323-gateway voip id cnibhco111 ipaddr 192.168.230.129 1719
h323-gateway voip h323-id cnibhco112
h323-gateway voip tech-prefix 71401
h323-gateway voip tech-prefix 0030
h323-gateway voip bind srcaddr 192.168.230.161
ip rsvp bandwidth 64 64
cnibhco112#sh tag-switching tdp neighbor
Peer TDP Ident: 192.168.254.1:0; Local TDP Ident 192.168.230.161:0
TCP connection: 192.168.254.1.49842 - 192.168.230.161.711
State: Oper; PIEs sent/rcvd: 18/23; Downstream
Up time: 00:12:54
TDP discovery sources:
FastEthernet0/0, Src IP addr: 192.168.230.162
Addresses bound to peer TDP Ident:
192.168.100.17 192.168.100.25 159.107.212.49 172.16.8.81
192.168.230.130 192.168.230.77 192.168.230.81 192.168.254.1
192.168.210.6 192.168.127.6 192.168.210.106 192.168.127.66
192.168.127.138 192.168.210.146 192.168.210.142 192.168.210.122
192.168.210.17 192.168.230.140 192.168.230.26 192.168.230.74
192.168.230.10 192.168.230.14 192.168.127.130 192.168.127.142
192.168.230.6 192.168.230.70 192.168.230.34 192.168.210.178
192.168.200.25 192.168.210.126 192.168.232.1 192.168.231.1
192.168.200.17 192.168.210.102 190.168.200.245 190.168.200.225
190.168.201.241 192.168.230.98 192.168.210.14 190.168.201.201
190.168.201.209 192.168.210.162 192.168.210.210 190.168.201.205
192.168.230.38 190.168.200.249 190.168.200.217 190.168.200.253
192.168.230.162
cnibhco112#
cnibhco112#sh tag-switching forwarding-table 192.168.254.1 detail
Local Outgoing Prefix Bytes tag Outgoing Next Hop
tag tag or VC or Tunnel Id switched interface
cnibhco112#traceroute 192.168.254.1
Tracing the route to 192.168.254.1
1 192.168.230.162 0 msec 0 msec *
cnibhco112#traceroute 192.168.230.162
Tracing the route to 192.168.230.162
cnibhco112#
10-24-2005 05:38 AM
ok first things first. Add the command mpls tdp router-id loopback 0 force if you can. Then you must be able to reach the loopbacks of each router i.e. use ospf or something.
10-25-2005 05:18 AM
Ro,
Thanks for the respone, have been playin, with MPLS for last few hours.
The routing between the loopbacks is now working, can PING 7609 Loopback from AS5350 ,and vice versa. (used static routes).
Having problem with TDP / LDP on routers,
mpls label protocol ldp / tdp command works correctly on both routers, but the
tag-switching tdp router-id Loopback0 force
command works on the 7609, but when I add it onto the AS5350 , the command "mpls ldp router-id Loopback0 force" appears on the startup script.
The opposite is true for the 7609 , you add MPLS LDP command, and TAG-SWITCHING command appears instead.
Any Ideas, as different configs of this leave me with forwarding table with both tags added, but not been able to ping the loopbacks !!!
When I can ping bot loopbacks, the OUTGOING TAG , disapears.....
Problem is LOOPBACK Commands on bot routers default to LDP (AS5350) , or TDP (7609). Any Ideas ...
cnibhco100#sh tag-switching forwarding-table 192.168.254.2 detail
18 17 192.168.254.0/24 0 Gi3/12 192.168.2
MAC/Encaps=14/18, MRU=1500, Tag Stack{17}
00097CA3293000127FCDBA808847 00011000
No output feature configured
Per-packet load-sharing
cnibhco100#traceroute 192.168.254.2
Tracing the route to 192.168.254.2
1 192.168.230.161 [MPLS: Label 17 Exp 0] 0 msec 0 msec 0 msec
2 192.168.230.162 0 msec 0 msec 0 msec
But no PINGING 192.168.254.2
17 18 192.168.254.0/24 1915668 Fa0/0 192.168.230.162
MAC/Encaps=14/18, MRU=1500, Tag Stack{18}
00127FCDBA8000097CA329308847 00012000
18 17 192.168.254.0/24 752551 Gi3/12 192.168.2
WHEN BOTH LOCAL AND OUTGOING TAG, CANNOT PING EITHER WAY !!!
HAVE LABEL PROTOCOL AND LOOPBACK FORCE on AS5350
HAVE LABEL PROTOCOL ON 7609
WHEN ADD LOOPBACK FORCE on 7609 , CAN PING BOTH LOOPBACKS,
BUT OUTGOING TAG DISAPEARS
cnibhco112#PING 192.168.254.2
Sending 5, 100-byte ICMP Echos to 192.168.254.2, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
17 Untagged 192.168.254.0/24 598678 Fa0/0 192.168.230.162
MAC/Encaps=0/0, MRU=1504, Tag Stack{}
cnibhco112#
