Unable to ping directly connected port from Cisco 1941
akhildevv
Hi Guys,
Since last few days i am facing one issue.
one of my MPLS customer edge device LAN is directly connected to Fortigate Firewall Port.
The issue is i am able to ping from Fortigate FW to my router port. But unable to ping from router to FW port.
Router port === Gi0/1 === 172.16.255.217
Firewall Port === Port 13 === 172.16.255.218
Results:
Router:
CE#ping 172.16.255.218 so 172.16.255.217
Sending 5, 100-byte ICMP Echos to 172.16.255.218, timeout is 2 seconds:
Packet sent with a source address of 172.16.255.217
Success rate is 0 percent (0/5)
FW:
FortiGate200E# exe ping 172.16.255.217
PING 172.16.255.217 (172.16.255.217): 56 data bytes
64 bytes from 172.16.255.217: icmp_seq=0 ttl=255 time=0.5 ms
64 bytes from 172.16.255.217: icmp_seq=1 ttl=255 time=0.3 ms
64 bytes from 172.16.255.217: icmp_seq=2 ttl=255 time=0.3 ms
64 bytes from 172.16.255.217: icmp_seq=3 ttl=255 time=69.1 ms
64 bytes from 172.16.255.217: icmp_seq=4 ttl=255 time=0.4 ms
--- 172.16.255.217 ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 0.3/14.1/69.1 ms
FortiGate200E#
Appreciate your advise.
Thanks & Regards,
Akhil
balaji.bandi
Check on Fortigate FW , by default most FW set to deny by default.
here is rule to add Fortinet FW :
https://kb.fortinet.com/kb/documentLink.do?externalID=FD38540
BB
Hi Balaji,
Ping rule is already allowed and enabled in the particular port. But still not sure why i can't ping from my cisco router even it is directly connected interface.
Akhil
balaji.bandi
Can you post the router config to have a look ? also what you see on Fortigate Logs ? is the ping reached and allowed in the Logs ?
BB
