Using hostname traceroute and VRF
ciscow_88
I'm having some difficulty using traceroute command using hostname as destination.
I am using VRF-lite on my router, the ping by hostname works fine for a particular VRF and
the traceroute by IP address also works fine.
But not traceroute by hostname, this is my problem.
Anyone ever use hostname/traceroute/vrf before? Any help would be appreciated.
Some info below, I've tried many combinations of commands, related to name resolution and vrf...
abc#ping vrf prd xyz                           <----------------------------This works
Sending 5, 100-byte ICMP Echos to x.x.x.x, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 60/62/64 ms
abc#
abc#clear host vrf prd *         <-----------------did this to start clean in cached host entries
abc#traceroute vrf prd xyz                           <--------Does not work
Translating "xyz"...domain server (x.x.x.x) [OK]     <--------Resolved to correct vrf/dns server
Translating "xyz"...domain server (255.255.255.255)  <--------Why this second check? I'm not using global ip name-server.
% Unrecognized host or address.
abc#
abc#traceroute vrf prd x.x.x.x   <---------------This works, same host but by IP.
Tracing the route to x.x.x.x
VRF info: (vrf in name/id, vrf out name/id)
  1 x.x.x.x 16 msec 20 msec 20 msec
  2 x.x.x.x 20 msec 20 msec 20 msec
  3 x.x.x.x 60 msec 60 msec 60 msec
  4 x.x.x.x 60 msec 60 msec 60 msec
abc#
ip domain lookup source-interface GigabitEthernet0/1.2  <---- in vrf prd
ip domain name vrf prd x.x.x.x
ip name-server vrf prd x.x.x.x
ip dns view vrf prd default                             <----created when above commands applied
0 Replies 0
