Various VPLS Mode
devang_etcom
Level 7
Level 7
I would like to know various types or mode of VPLS.
As per Cisco standerds its: Port mode and VLAN mode.
Now I would like to know if I can use the PE interface connected to CE as a trunk interface and carry all customer VLAN via that port? Instread of creating multiple subninterfaces of the interface and put them on different instances or VPLS instances?
Is there any good document, site or blog that shows various VPLS deployment mode along with VPLS redundancy scenarios?
Devang
rsimoni
Hi Devang,
not sure if you are refrring to vc-types instead.
However you can use a trunk port for the PE to CE AC
have a look at
http://www.cisco.com/en/US/docs/routers/7600/install_config/ES40_config_guide/es40_chap6.html#wp1460517
Or you can explore the EVC world (if you have the right hw) and have a more flexible approach.
Riccardo
