Hi all,
I am trying to terminate a EoMPLS Tunnel with a virtual L3 interface on a ASR1000 without any physical port interaction.
We need to send the Traffic from Subinterfaces of some PE's (7600 and ASR9k) to an ASR1000 which sould use ISG functionallity to authorize and bw-limit the subscribers.
On the current setup we terminate the xconnects on a 7600 PE as well, and we send the traffic dot1q tagged to the ISG which is the L3 endpoint for the customers.
To make the switchover from a failed device easier, we now want to terminate everything on the ASR1000. Im my understanding, this shoud be possible with an l2 vfi, with an configured bridge-domain with BDI Interface and an EoMPLS neighbor.
The config I tired on the ASR1000 looks like:
l2 vfi vfi50 manual
vpn id 50
bridge-domain 50
neighbor <PE IP> 103685 encapsulation mpls
interface BDI50
vrf forwarding ISG_TABLE
ip address <Service IP> <netmask>
ip helper-address <DHCP>
load-interval 30
The communication from the Customer Network to the DHCP works, and I can even ping the BDI Interface IP, but I can not get further to the internet. Pinging a public address from the BDI50 Interface however works fine.
When I do a debug ip packet on that range, I can only see broadcasted packets (which get forwarded to the helper address).
However, MAC Adresses and ARP tables and gateway on the client looks good:
ar90.bie005.bb#sh bridge-domain 50
Bridge-domain 50 (2 ports in all)
State: UP Mac learning: Enabled
Aging-Timer: 180 second(s)
BDI50 (up)
vfi vfi50 neighbor <PE IP> 103685
MAC address Policy Tag Age Pseudoport
C84C.75E1.CEBF to_bdi static 0 BDI50
88AE.1DAA.502A forward dynamic 179 vfi50.1020017 #88AE.1DAA.502A = Lab Laptop
ar90.bie005.bb#sh xconnect all
XC ST Segment 1 S1 Segment 2 S2
UP pri vfi vfi50 UP mpls <PE IP>:103685 UP
UP pri bd 50 UP vfi vfi50 UP
ar90.bie005.bb#sh ip arp vrf ISG_TABLE
Protocol Address Age (min) Hardware Addr Type Interface
Internet <SERVICE Address> - c84c.75e1.cebf ARPA BDI50
Internet <Lab Laptop IP> 0 88ae.1daa.502a ARPA BDI50
Am I missing something? Is there a limitation I am hitting? In the most documents I found there was always a Service Instance on an Interface involved, which is certainly missing here.
Thaks for any help!
Hi Gregor,
Did you end up resolving this? Am quite intrested to see what was needed.
Mick
yes actually it should be fixed ;-)
It was a bug on the ASR (
CSCub44215), it had somehow problems with that routed vpls scenareo with routes learned from mp-bgp.
I could verify the fix of the problem with an engineering release, however, I did not have time to check the functionallity on Software Version 3.7.1.S / 15.2(4)S1 where the fix of the bug was implemented officially. But I'm very confident that it will work with that version as well.
