vlans and routing
isaaco001
Level 3
Level 3
Dear Community, I have created vlan 2 for data and voice.The switch is the dhcp server for data and the router dns-server. I need to create a separate vlan for voice only with separate dhcp server for voice on the switch.Is this possible?If yes, what do i need to configure for this setup to work.Examples will be really helpful in my case.Please find the running configs for the router and switch.NOTE:OPEN WITH NOTEPAD ++ Thanks.
Mark Malone
voice and data port should be connected one interface like below to save port space connect pc to phone then to port
Just examples to go by
create vlans
vlan 10
name data
vlan 2
name voice
set ports
interface x/x
switch access vlan 10
switchport voice vlan 2
spanning-tree portfast
spanning-tree bpduguard enable
On your router if there L3 ports you need to use sub-interfaces as your vlan breakouts as i dont see a switching module for a trunk so router side will be sub-ints switch side trunk
see this doc for clear example
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/336-cisco-router-8021q-router-stick.html
DHCP
you already have 1 pool just create another one , one for each subnet then your gateway will be the sub-interface for each vlan from the doc above
dont use the router as DNS server wont work well , use google in your dhcp pool or another actual dns server
Let me know if you get stuck
Mark Malone
create vlans
vlan 10
name data
vlan 2
name voice
set ports
interface x/x
DHCP
