VPLS and H-VPLS
prakashj
I have ME3750 as uPE and 7600 as nPE. Now I want to extend VPLS from ME3750 to two other ME3750s. The ME3750 is connected to 6724 in 7600.
Can I run H-VPLS between 3750 (extend EoMPLS to nearest nPE)and 7600 and run VPLS directly from 7600. Does 7600 support H-VPLS with 6724 as downlink module. I have ES20 as uplink module on 7600 connected to the core.
Prakash
5 Replies 5
emaamur2006
Hi Prakash
I believe as long as you have sup-720 in the 7600, you can have the solution you described. See config below
3750
Vlan 100
interface fastEthernet x/y
switchport mode dot1q-tunnel ! H-VPLS
switchport access vlan
7600
l2 vfi ip vrf Manual
vpn id 100
neighbor < Other nPe 7600> Encapsulation Mpls
Vlan 100
Interface vlan 100
xconnect Vfi
Maamun
Thanks Maamun,
But I want to configure H-VPLS using AToM tunnel (EoMPLS) from ME 3750 to 7600..I want to configure ME3750 as L3 node.
Also is there any way to have EoMPLS redundancy on ME3750?
Prakash
Hi Prakash
Please have a look at this link for L2VPN redundancy
http://www.cisco.com/en/US/products/sw/iosswrel/ps1829/products_feature_guide09186a0080606811.html
Maamun
Prakash Maamun,
The feature may not be supported on all devices. Do check the support for your to be deployed devices.
HTH-Cheers,
Swaroop
The ME3750 does not support...so there is no other way to provide EoMPLS redundancy :(
