VPLS BGP Signaling between ASR9K & Junos
belalcciejo
I have configured VPLS bgp signaling between ASR & Junos the VPLS  connection from Junos side indicate it’s up without any problem but from ASR side it’s down
The following output form Junos & ASR
RP/0/RSP0/CPU0:IGW-LON-1#show l2vpn bridge-domain bd-name MPLSL2VPN
Thu Jun 7 18:56:38.028 UTC
Bridge group: MPLSl2VPN, bridge-domain: MPLSL2VPN, id: 0, state: up, ShgId: 0, MSTi: 0
Aging: 300 s, MAC limit: 4000, Action: none, Notification: syslog
Filter MAC addresses: 0
ACs: 1 (1 up), VFIs: 1, PWs: 1 (0 up), PBBs: 0 (0 up)
List of ACs:
   Gi0/0/0/0, state: up, Static MAC addresses: 0
List of Access PWs:
List of VFIs:
   VFI L2VPN
     Neighbor 192.168.255.3 pw-id 2, state: down, Static MAC addresses: 0
RP/0/RSP0/CPU0:IGW-LON-1#show l2vpn bridge-domain bd-name MPLSL2VPN detail
Thu Jun 7 18:56:44.522 UTC
MAC learning: enabled
MAC withdraw: enabled
   MAC withdraw for Access PW: enabled
Flooding:
   Broadcast & Multicast: enabled
   Unknown unicast: enabled
MAC aging time: 300 s, Type: inactivity
MAC limit reached: no
MAC port down flush: enabled
MAC Secure: disabled, Logging: disabled
Split Horizon Group: none
Dynamic ARP Inspection: disabled, Logging: disabled
IP Source Guard: disabled, Logging: disabled
DHCPv4 snooping: disabled
IGMP Snooping profile: none
Bridge MTU: 1500
MIB cvplsConfigIndex: 1
Create time: 04/06/2012 08:00:37 (3d10h ago)
No status change since creation
List of ACs:
   AC: GigabitEthernet0/0/0/0, state is up
     Type Ethernet
     MTU 1500; XC ID 0x840001; interworking none
     Flooding:
     Storm Control: disabled
     Statistics:
       packets: received 111042690, sent 19
       bytes: received 6662562344, sent 1562
     Storm control drop counters:
       packets: broadcast 0, multicast 0, unknown unicast 0
       bytes: broadcast 0, multicast 0, unknown unicast 0
     Dynamic ARP inspection drop counters:
       packets: 0, bytes: 0
     IP source guard drop counters:
List of Access PWs:
List of VFIs:
   VFI L2VPN
     VPN-ID: 2, Auto Discovery: BGP, state is Provisioned (Service Connected)
     Route Distinguisher: 65555:800
     Import Route Targets:
       65555:800
     Export Route Targets:
       65555:800
     Signaling protocol: BGP
     Local VE-ID: 2 , Advertised Local VE-ID : 2
     VE-Range: 10
     PW: neighbor 192.168.255.3, PW ID 2, state is down ( all ready ) (Transport LSP Down)
       PW class not set, XC ID 0xfffc0002
       Encapsulation MPLS, Auto-discovered (BGP), protocol BGP
       PW type VPLS, control word disabled, interworking none
       PW backup disable delay 0 sec
       Sequencing not set
         MPLS         Local                         Remote
         Label       16015                         262210
         MTU         1500                           unknown
         Control word disabled                       disabled
          PW type     VPLS                           VPLS
         VE-ID       2                             1
        MIB cpwVcIndex: 4294705154
       Create time: 07/06/2012 11:52:11 (07:04:32 ago)
       Last time status changed: 07/06/2012 11:52:11 (07:04:32 ago)
       MAC withdraw message: send 0 receive 0
     VFI Statistics:
       drops: illegal VLAN 0, illegal length 0
show vpls connections instance MPLSL2VPN-INTER-AS extensive
Layer-2 VPN connections:
Legend for connection status (St)
EI -- encapsulation invalid     NC -- interface encapsulation not CCC/TCC/VPLS
EM -- encapsulation mismatch     WE -- interface and instance encaps not same
VC-Dn -- Virtual circuit down   NP -- interface hardware not present
CM -- control-word mismatch     -> -- only outbound connection is up
CN -- circuit not provisioned   <- -- only inbound connection is up
OR -- out of range              Up -- operational
OL -- no outgoing label         Dn -- down
LD -- local site signaled down   CF -- call admission control failure
RD -- remote site signaled down SC -- local and remote site ID collision
LN -- local site not designated LM -- local site ID not minimum designated
RN -- remote site not designated RM -- remote site ID not minimum designated
XX -- unknown connection status IL -- no incoming label
MM -- MTU mismatch               MI -- Mesh-Group ID not availble
BK -- Backup connection         ST -- Standby connection
PF -- Profile parse failure     PB -- Profile busy
RS -- remote site standby       SN -- Static Neighbor
Legend for interface status
Up -- operational
Dn -- down
Instance: MPLSL2VPN-INTER-AS
Local site: 1 (1)
   Number of local interfaces: 1
   Number of local interfaces up: 1
   IRB interface present: no
   ge-11/0/1.431
   lsi.1049371         2         Intf - vpls MPLSL2VPN-INTER-AS local site 1 remote site 2
   Label-base       Offset     Size Range     Preference
   262209           1         8     8         100
   connection-site           Type St     Time last up         # Up trans
   2                         rmt   Up     Jun 7 14:55:39 2012           1
     Remote PE: 192.168.106.201, Negotiated control-word: No
     Incoming label: 262210, Outgoing label: 16015
     Local interface: lsi.1049371, Status: Up, Encapsulation: VPLS
       Description: Intf - vpls MPLSL2VPN-INTER-AS local site 1 remote site 2
   Connection History:
       Jun 7 14:55:39 2012 status update timer
       Jun 7 14:55:39 2012 loc intf up                 lsi.1049371
       Jun 7 14:55:39 2012 PE route changed
       Jun 7 14:55:39 2012 Out lbl Update                     16015
       Jun 7 14:55:39 2012 In lbl Update                     262210
       Jun 7 14:55:39 2012 loc intf down
Eric Guo
hello
has  your problem been resolved already ? since I am starting work on same setup right now. could you mind share your Cisco end configuration to me without your confidential information?
thanks, please let me know if possible.
Eric
