VPLS configuration clarification
Gaurav Madan
Hi Team
I am referring to link :
http://www.akbintel.com/mediawiki/index.php/VPLS/Config
Case :
CE1			CE2
SW1 - PE1 - P1 - PE2 - SW2
CE3			CE4
!! CE1-CE2 are in VLAN12
!! CE3-CE4 are in VLAN34
I want CE1 to talk to CE2 and similarly CE3 to talk to CE4 . My config looks like following :
l2vpn
 pw-class VPLS_CLASS
  encapsulation mpls
  transport-mode ethernet
 bridge group VPLS_GROUP
  bridge-domain VLAN12
   $INT_TO_PE1_CE1.12
   vfi 12
    neighbor $PE2_lo0 pw-id 12
     pw-class VPLS_CLASS
  bridge-domain VLAN34
   $INT_TO_PE1_CE1.34
   vfi 34
    neighbor $PE2_lo0 pw-id 34
    pw-class VPLS_CLASS
My question is :
On a very high level ; can you please explain what is VFI functionality here ?
1) Do I need to create as many VFIs to make as many vlans on either side talk to each other ? For example in above case ; vfi12 is created to make vlan 12 talk to each other ans similarly vfi34 to make vlan 34 talk .
2) or can we have a vfi to make multiple Vlans talk to each other
What will be difference in 2 approaches ?
Gaurav Madan
On another document ; I read following 2 points :
VPLS Uses a Virtual Forwarding Instances (VFI, like VLAN) for customer separation
•VFI creates L2 multipoint bridging among all ACs and VCs. It’s L2 broadcast domain like VLAN
• Multiple VFIs can exist on the same PE box to separate user traffic like VLAN
Hence if I say ; customer A wants vlan 10 and 20 to talk between 2 diff sites
                         customer B wants to talk vlan 100 and 200 to talk between 2 diff sites
SW1(vlan 10,20)  - PE1 - P1 - PE2 - (vlan 10,20) SW2
SW3(vlan 100,200)----|		|-----(vlan 100,200) SW4
SW1 , SW2 : cust A
SW3 , Sw4 : cust B
Can i have config like :
int ten 0/0/0/0.10
vfi 12
int ten 0/0/0/0.20 !
vfi 12
   neigh $PE2 pw-id 12
int ten 0/0/0/1.100
vfi 34
int ten 0/0/0/1.200
vfi 34
   neigh $PE2 pw-id 12
