VPLS switch instance
cisco_raj
Level 2
Level 2
Hi Friends.
Consider a scenario for single metro H-VPLS:
CE1-->MTU-s-->PE-RS1-->PE-RS2
PE-RS3
A single spoke Pseudowire is setup between the MTU-s and PE-RS1. Will there be a unique VCID for this Pseudowire???Say if there's one more MTU say MTU-s' connecting to PE-RS1, will there be two different Pesudowires and virtual circuits setup between PE-RS1 to MTU-s and PE-RS1 to MTU-s'?????Will there be two differnt VPLS switch instance for connectivity between PE-RS1 and MTU-s and PE-RS1 and MTU-s'????
I'm unable to understand the difference between Single spoke Pseudowire,Virtual circuit and VPLS Switch instance!!!!!!
Thanx
RAJ
mithil_r
Level 2
Level 2
Raj,
Find the attachment herein and see whether that answers ur all questions.
MITHIL
mithil_r
Level 2
Level 2
Raj,
MITHIL
Hi Mithil,
That's fine. I'm trying to understand the concept. Well, ur pdf is useful I should say!!!
THNX
RAJ
judebryant
Level 3
Level 3
Lets take this a bit further.
Pseudo-wire point to point(only)
allows specific VLan(s)
doesnt learn Mac-addresses.
VPLS
Point to point(e-line)
point to multi-point(e-tree)
multipoint to multipoint(e-lan)
mac-addresses learned so if point to point use pseudo-wires.
use neighbor statements to control branches, and split-horizon to protect from loops
use mac-in-mac to control learned mac-address.
Jude
