VPNV4 label allocation
dfauluchi
Hi!
I have a question about label allocation. I can't figure out how can I controll this behavior.
I have a few PEs, all of them ASR9010.
There's one that allocates a new local label for each vpnv4 prefix it receives from RR, even if label mode per-vrf is configured. Right now it has assigned 540K labels, there are no labels available for FRT.
sh mpls label table summary
Thu May 13 18:09:23.996 GMT
Application Count
LSD(A) 4
BGP-VPNv4(A):bgp-default 540117
LDP(S) 937
L2VPN(A) 1492
LDP(A) 978
BGP-VPNv4(S):bgp-default 540117
TOTAL 542140
- Why would assign local labels for prefixes it's not advertising?
- Why label mode per-vrf does not change this behavior.
There’s another PE with FRT (823K prefixes, 1.7M paths) and it’s using ~1.5k labels.
This second one does not assign one label for each vpnv4 prefix it receives from RR.
Thu May 13 18:11:30.656 GMT
Application Count
LSD(A) 4
LDP(A) 186
BGP-VPNv4(A):bgp-default 1291
LDP(S) 44
BGP-VPNv4(S):bgp-default 1291
TOTAL 1469
The question is which conditions make these 2 routers to behave differently?
In my LAB I found that in some routers, using next-hop-self in vpnv4 session with RR will demand labels. Removing it frees label space.
In other routers that initially demanded label allocation, removing next-hop-self in vpnv4 session doesn’t free label space.
Other guess is that being an inline-RR may affect this behavior.
Thanks!!!
Hi Diego,
Thanks for the additional info. Here are a few observations.
To reduce both, this PE generates a default route per vrf and sits as next hop only for these RR clients and only for the 2 vrfs they use.
I suppose that you only allow the default route towards the smaller PE?
The next-hop-self is what is causing the issue, but I am not sure why the PE (20.10.10.17) with more resources needs to be inline for traffic going toward the smaller PE (20.10.10.25). I think you could safely remove the next-hop-self. This would solve the issue.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
México móvil: +52 1 55 8312 4915
Cisco México
Paseo de la Reforma 222
Piso 19
Cuauhtémoc, Juárez
Ciudad de México, 06600
México
10 Replies 10
Harold Ritter
Hi @dfauluchi ,
VPNv4 label allocation occurs on the egress PE, not on the ingress PE. The PE receiving the VPNv4 prefixes from the RR will not allocate local labels for those prefixes.
When per-VRF allocation mode is configured on a given PE, that PE will allocate 1 aggregate label per locally attached VRF.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi Harold,
Thanks for your answer.
I agree with you, about label allocation, but it's happening. So there must be certain conditions in which it occours.
One thing I found in my lab is that label allocation for thore prefixes is done when we have next-hop-self in the vpnv4 session to the RR. But removing next-hop-self does not always remove those labels. So I think there are more conditions.
This PE is also an inline RR, perhaps it's another condition.
This is a fragment of my mpls forwarding table i've taken from my PE, where 20.10.10.9 emulates an IGW and 20.10.10.9:3200 is the RD of my emulated FRT.
IGW is advertising one label per vrf: 24047, and this PE allocates one label for each vpnv4 prefix:
24277 24047 20.10.10.9:3200:100.64.228.0/24 \
20.10.10.9 0
24278 24047 20.10.10.9:3200:100.64.229.0/24 \
20.10.10.9 0
24279 24047 20.10.10.9:3200:100.64.230.0/24 \
20.10.10.9 0
24280 24047 20.10.10.9:3200:100.64.231.0/24 \
20.10.10.9 0
24281 24047 20.10.10.9:3200:100.64.232.0/24 \
20.10.10.9 0
24282 24047 20.10.10.9:3200:100.64.233.0/24 \
20.10.10.9 0
24283 24047 20.10.10.9:3200:100.64.234.0/24 \
20.10.10.9 0
24284 24047 20.10.10.9:3200:100.64.235.0/24 \
So label table gets full before I can reveive FRT.
Any idea why is it happening?
Thanks in advance!
Diego
Thanks for the additional info @dfauluchi ,
It would definitely help to get the configuration of this PE. Also, could you please tell me what you mean by FRT?
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi Harold,
I'm sorry I didn't explain this earlier. FRT is the internet routing table.
HL3 are upstream routers which act as inline RR. In my lab they are also Internet Gateways.
HL5 are ipv4 LU and vpnv4 RR clients. This PE is an inline RR too.
vrf INT
address-family ipv4 unicast
import route-target
65000:3204
export route-target
65000:3203
router bgp 65000
nsr
bfd minimum-interval 50
bfd multiplier 3
bgp router-id 20.10.10.17
bgp graceful-restart
bgp log neighbor changes detail
ibgp policy out enforce-modifications
additional-paths receive
additional-paths send
additional-paths selection route-policy BGP-PIC
network 20.10.10.17/32 route-policy aigp_policy
redistribute connected
allocate-label all
address-family vpnv4 unicast
retain route-target all
address-family ipv4 rt-filter
neighbor-group HL3
remote-as 65000
bfd fast-detect
advertisement-interval 1 0
update-source Loopback0
address-family ipv4 labeled-unicast
aigp
next-hop-self
aigp
next-hop-self
neighbor-group HL5
remote-as 65000
bfd fast-detect
update-source Loopback1
aigp
route-reflector-client
capability orf prefix receive
next-hop-self
neighbor 20.10.10.9
use neighbor-group HL3
description ASR9010-1515
neighbor 20.10.10.15
description HL3-1-POP-2
neighbor 20.10.10.25
use neighbor-group HL5
description HuaweiATN910i_15-35-1
vrf INT
rd 20.10.10.17:3200
Kind regards.
Hi Diego,
The issue is that this PE is configured as a RR (route-reflector-client). It is reflecting the VPNv4 prefixes received from neighbor 20.10.10.9 to neighbor 20.10.10.25. And since you also configured next-hop-self, which makes it an inline RR, the PE allocates a local label for each and every VPNv4 prefix, hence the issue you are seeing.
Can you explain why this PE is configured as a RR for VPNv4 routes?
Removing the route-reflector-client from address-family vpnv4 unicast under neighbor-group HL5 should solve the issue.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi Harold,
First I'll try to explain why we need this PE as an inline RR.
Downstream routers are not capable of handling large route tables or have small label table (~500). To reduce both, this PE generates a default route per vrf and sits as next hop only for these RR clients and only for the 2 vrfs they use. All other prefixes are filtered. When upstream packets arrive to PE is able to send it to destination.
I understand why it's using labels. Now, what I would like to achieve is to scale. We are just starting and label table is at 55%. And it looks like any new vpnv4 prefix in any point in the network will consume 2 labels in this PE. No mention for full internet table.
I tried using label mode per-vrf (global and per vrf), but still allocates one label per prefix.
There are 2 RR for vpnv4 and 2 dedicated RR for internet table (also vpnv4). I will try to reproduce this in my lab and see if behavior is affeced by next-hop-self.
Thanks for helping me out.
Best regards, Diego.
Hi Diego,
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
Hi Harold,
I will test that in my LAB.
Thanks a lot!
Best regards!
Hi!
We see that having an Inter-AS op B also triggers label allocation for all vpnv4 prefixes. And it does not depend on next-hop-self.
Is there any way to overcome this?
router bgp 65000
neighbor A.B.C.D
  remote-as 65001
  update-source Bundle-Ether600.600
   route-policy L3VPN in
   route-policy L3VPN out
   soft-reconfiguration inbound always
Thanks in advance!
Diego.
Hi Diego,
This is indeed the normal behavior.
next-hop-self is the default behavior for eBGP, so will behave as next-hop-self without configuring it.
The only way I can think of would be to move to option C.
Harold Ritter
Sr Technical Leader
CCIE 4168 (R&S, SP)
harold@cisco.com
Cisco México
Piso 19
Cuauhtémoc, Juárez
México
