VRF-Lite using RIP and redistribute connected
scorpion
I am having some problem with VRF-LITE using RIP and redistribute connected. VRF-Lite is configured between a Cisco 7204VXR running
c7200p-advipservicesk9-mz.124-24.T4.bin and a Cisco ME 3400 running me340x-metroipaccess-mz.122-35.SE4.bin. The configurations are as following :
ROUTER-A(7200 VXR)
ip vrf A
rd 1:1
route-target export 1:1
route-target import 1:1
interface GigabitEthernet0/0
description ** INFR - SW1 **
no ip address
duplex full
speed 1000
media-type gbic
negotiation auto
no cdp enable
interface GigabitEthernet0/0.11
description ** CLIENT A-VID11 **
encapsulation dot1Q 11
ip vrf forwarding A
ip address 172.16.3.1 255.255.255.252 secondary
ip address 172.16.101.1 255.255.255.252
ip flow ingress
no cdp enable
router bgp 38712
address-family ipv4 vrf A
  redistribute rip
  no synchronization
exit-address-family
router rip
  redistribute bgp 65534 metric transparent
  network 10.0.0.0
  network 172.16.0.0
  no auto-summary
  version 2
exit-address-family
ROUTER-B(7200VXR)
ip vrf A
rd 1:1
no ip address
duplex full
speed 1000
media-type gbic
negotiation auto
no cdp enable
ip vrf forwarding A
ip address 172.16.102.1 255.255.255.252
ip flow ingress
no cdp enable
router bgp 38712
  no synchronization
exit-address-family
SWITCH-A(ME 3400)
ip vrf A
rd 1:1
vlan 11
name A
interface FastEthernet0/1
description ** INFR - ROUTER **
port-type nni
switchport mode trunk
interface FastEthernet0/2
description ** A-BRANCH-1-DATA-L3VPN **
no switchport
ip vrf forwarding A
ip address 10.222.25.129 255.255.255.252
interface FastEthernet0/3
description ** A-BRANCH-2-DATA-L3VPN **
no switchport
ip vrf forwarding A
ip address 10.222.25.137 255.255.255.252
interface Vlan11
description ** A **
ip vrf forwarding A
ip address 172.16.101.2 255.255.255.252
router rip
version 2
network 10.0.0.0
network 172.16.0.0
no auto-summary
version 2
exit-address-family
end
Output of ROUTER A
Routing Table: A
Gateway of last resort is not set
      172.16.0.0/16 is variably subnetted, 3 subnets
B       172.16.102.0/30 [200/0] via A.B.C.D, 7w0d
C       172.16.101.0/30 is directly connected, GigabitEthernet0/0.11
C       172.16.3.0/30 is directly connected, GigabitEthernet0/0.11
     10.0.0.0/8 is variably subnetted, 2 subnets
R       10.222.25.136/30
           [120/1] via 172.16.101.2, 00:00:11, GigabitEthernet0/0.11
R       10.222.25.128/30
           [120/1] via 172.16.101.2, 00:00:12, GigabitEthernet0/0.11
Output of ROUTER B
Routing Table: A
C       172.16.102.0/30 is directly connected, GigabitEthernet1/0.11
B       172.16.3.0/30 [200/0] via B.C.D.E, 6w5d
B       172.16.101.0/30 [200/0] via B.C.D.E, 3w5d
B       10.222.25.136/30 [200/1] via B.C.D.E, 5d06h
B       10.222.25.128/30 [200/1] via B.C.D.E, 5d06h
Output of SWITCH A
Routing Table: A
Gateway of last resort is 172.100.101.1 to network 0.0.0.0
     172.100.0.0/16 is variably subnetted, 2 subnets
R       172.16.102.0/30 [120/1] via 172.16.101.1, 00:00:10, Vlan11
C       172.16.101.0/30 is directly connected, Vlan11
C       10.222.25.136/30 is directly connected, FastEthernet0/3
C       10.222.25.128/30 is directly connected, FastEthernet0/2
Now the problem is although there is an IP address 172.16.3.0/30 connected in ROUTER A and I have configured "redistribute connected" in rip but that route is not advertised to the switch. What am I missing?
You could try to disable split-horizont on that interface ;
Router A
no ip split-horizon
Dan
Router A
no ip split-horizon
Dan
