XConnect between 3750 SVI and ASR 9010 Bridge-domain as Access PW
Victor S
Hi, I'm having some doubts regarding the inability to bring up this xconnect between an ASR 9010 and a 3750 SVI, this is the setup:
ASR9010 (1.1.1.1) Bridge-Domain Access PW -------------- MPLS Cloud ---------------- 3750 SVI (2.2.2.2) xconnect
I understand that the SVI xconnect is going to be a VLAN type 4 xconnect, however, the ASR 9010 doesn't let me make the Access PW inside of the BD a VLAN mode pseudowire, I get the following:
!!% Invalid argument: Only ethernet/vlan passthrough transport mode is supported in VPLS
Here are the configurations, hardware/software versions and show command outputs:
ASR 9010 - Cisco IOS XR Software, Version 5.3.3[Default]
pw-class RAW-MODE-PW
encapsulation mpls
transport-mode ethernet
ipv4 source 1.1.1.1
pw-class VLAN-MODE-PW
encapsulation mpls
transport-mode vlan
ipv4 source 1.1.1.1
pw-class VLAN-MODE-PASSTHROUGH
encapsulation mpls
transport-mode vlan passthrough
ipv4 source 1.1.1.1
l2vpn
bridge group TEST
bridge-domain TEST-MGT
interface Bundle-Ether10.50090
storm-control unknown-unicast pps 250
storm-control multicast pps 250
storm-control broadcast pps 250
neighbor 2.2.2.2 pw-id 90
pw-class VLAN-MODE-PASSTHROUGH <<
routed interface BVI90
If using VLAN-MODE-PASSTHROUGH:
RP/0/RSP1/CPU0:TAMP86-SER1#show l2vpn bridge-domain group TEST bd-name TEST-MGT detail | begi List of Acces
Tue Jun 20 07:33:14.416 EST
List of Access PWs:
PW: neighbor 209.16.124.96, PW ID 90, state is unresolved (Bridge PW Type mismatch)
Static MAC addresses:
MAC learning: enabled
Flooding:
Broadcast & Multicast: enabled
Unknown unicast: enabled
MAC aging time: 300 s, Type: inactivity
MAC limit: 4000, Action: none, Notification: syslog
MAC limit reached: no
MAC port down flush: enabled
MAC Secure: disabled, Logging: disabled
Split Horizon Group: none
DHCPv4 snooping: disabled
IGMP Snooping: enabled
IGMP Snooping profile: none
MLD Snooping profile: none
Storm Control: bridge-domain policer
If using RAW-MODE-PW:
RP/0/RSP1/CPU0:TAMP86-SER1#show l2vpn bridge-domain group EDGE bd-name BSS-MGT detail | begi List of Acces
Tue Jun 20 07:34:55.490 EST
List of Access PWs:
PW: neighbor 209.16.124.96, PW ID 90, state is down ( all ready ) (Segment-down)
PW class RAW-MODE-PW, XC ID 0xc0000081
Encapsulation MPLS, protocol LDP
Source address 71.44.0.86
PW type Ethernet, control word disabled, interworking none
PW backup disable delay 0 sec
Sequencing not set
MPLS Local Remote
Label 25785 16
Group ID 0x0 0x0
Interface Access PW TEST-MGMT-VLAN90
MTU 1500 1536
Control word disabled disabled
PW type Ethernet Ethernet VLAN
VCCV CV type 0x2 0x2
(LSP ping verification) (LSP ping verification)
VCCV CC type 0x6 0x2
(router alert label) (router alert label)
(TTL expiry)
MIB cpwVcIndex: 3221225601
Create time: 30/09/2015 16:48:28 (3w4d ago)
Last time status changed: 25/10/2015 20:39:33 (00:00:05 ago)
MAC withdraw messages: sent 0, received 0
Error: PW type mismatched
Flooding:
cisco ME-C3750-24TE (PowerPC405) 12.2(44)SE1
interface Vlan90
description TEST-MGMT-VLAN90
no ip address
xconnect 1.1.1.1 90 encapsulation mpls
end
BPR1# show mpls l2transport vc 90 detail
Local interface: Vl90 up, line protocol up, Eth VLAN 90 up
Destination address: 1.1.1.1, VC ID: 90, VC status: down
Output interface: if-?(0), imposed label stack {}
Preferred path: not configured
Default path: no route
No adjacency
Create time: 41w1d, last status change time: 14:15:19
Signaling protocol: LDP, peer 1.1.1.1:0 up
Targeted Hello: 2.2.2.2(LDP Id) -> 1.1.1.1
Status TLV support (local/remote) : enabled/unknown (no remote binding)
Label/status state machine : local ready, LruRnd
Last local dataplane status rcvd: no fault
Last local SSS circuit status rcvd: no fault
Last local SSS circuit status sent: DOWN(not-forwarding)
Last local LDP TLV status sent: no fault
Last remote LDP TLV status rcvd: unknown (no remote binding)
MPLS VC labels: local 16, remote unassigned
Group ID: local n/a, remote unknown
MTU: local 1536, remote unknown
Remote interface description:
Sequencing: receive disabled, send disabled
VC statistics:
packet totals: receive 0, send 110
byte totals: receive 0, send 7480
packet drops: receive 0, send 0
Any help/advice would be very much appreciated.
Thank you.
0 Replies 0
