xconnect TE Problem
jakskal07
Community Member
Hi ... we have xconnect problem between our PE-Router when we apply TE on this xconnect. The xconnect is between Cisco 7600 (s72033-advipservicesk9_wan-mz.122-33.SRA3.bin) and Cisco 7206 NPEG2 (c7200p-advipservicesk9-mz.124-11.T3.bin). The problem is xconnect from 7600 to 7206 is up, but xconnect from 7206 to 7600 is down. We have try to test this TE xconnect to different PE, but still got same symptom. There's no problem if we don't apply TE on this xconnect.
The path from TE is:
PE(7606) - P(7606) - PE(7206). The TE path between 7606 to 7206 and 7206 to 7606 is via same physical path.
Cisco-7606:
#sh mpls l2transport vc 896 detail
Local interface: Po1.896 up, line protocol up, Eth VLAN 896 up
Destination address: 116.199.192.146, VC ID: 896, VC status: up
Output interface: Tu5, imposed label stack {57 41}
Preferred path: Tunnel5, active
Default path: disabled
Next hop: point2point
Create time: 00:00:23, last status change time: 00:00:23
Signaling protocol: LDP, peer 116.199.192.146:0 up
MPLS VC labels: local 19, remote 41
Group ID: local 0, remote 0
MTU: local 1500, remote 1500
Remote interface description:
Sequencing: receive disabled, send disabled
VC statistics:
packet totals: receive 0, send 0
byte totals: receive 0, send 0
packet drops: receive 0, send 0
Cisco 7206:
Local interface: Gi0/2.896 up, line protocol up, Eth VLAN 896 up
Destination address: 116.199.192.130, VC ID: 896, VC status: down
Preferred path: Tunnel1, active
Output interface: unknown, imposed label stack {}
Create time: 3d23h, last status change time: 00:00:12
Signaling protocol: LDP, peer 116.199.192.130:0 up
MPLS VC labels: local 41, remote 19
VC statistics:
packet drops: receive 0, seq error 0, send 171145
Appreciate if someone can help.
thks,reza
6 Replies 6
shivlu jain
Level 9
Level 9
Please check the TE in the whole path. If possible post the configs.
regards
shivlu jain
hi shivlu,
there's no problem with TE path, and already test some TE between my 7606-PE to several 7206-PE, and got some result.
the TE config is like this:
7606-PE:
ip explicit-path name METRO_BDG_MORA-GIG-1/5 enable
next-address xxx.xxx.xxx.xxx
next-address xxx.xxx.xxx.xxx --> 7206-PE Loopback 0 IP address
interface Tunnel5
ip unnumbered Loopback0
tunnel destination xxx.xxx.xxx.xxx --> 7206-PE Loopback 0 IP address
tunnel mode mpls traffic-eng
tunnel mpls traffic-eng autoroute announce
tunnel mpls traffic-eng path-option 1 explicit name METRO_BDG_MORA-GIG-1/5
tunnel mpls traffic-eng path-option 2 dynamic
tunnel mpls traffic-eng record-route
tunnel mpls traffic-eng load-share 10
pseudowire-class TE_METRO_BDG_MORA_GIG-1/5
encapsulation mpls
preferred-path interface Tunnel5 disable-fallback
7206-PE:
ip explicit-path name BDG_METRO_MORA-GIG-0/1 enable
next-address xxx.xxx.xxx.xxx --> 7606-PE Loopback 0 IP address
interface Tunnel1
tunnel destination xxx.xxx.xxx.xxx --> 7606-PE Loopback 0 IP address
tunnel mpls traffic-eng path-option 1 explicit name BDG_METRO_MORA-GIG-0/1
tunnel mpls traffic-eng path-option 2 explicit name BDG_METRO_XL-SE-6/0
pseudowire-class TE_BDG_METRO_MORA_GIG-0/1
encapsulation mpls
preferred-path interface Tunnel1 disable-fallback
Reza,
This is a bug. You should move to the latest 12.4T, where it should work just fine.
Tehards
Hi Tehards,
Thks for your info. Is both 7606 & 7206 should upgrade to 12.4T ?
Thks,
Reza
Reza,
The issue is on the 7206. You just need to upgrade this router to the latest 12.4T.
Thks for info, will try this
