I have upgraded from 4.6.1 to 4.7.0 to 4.8.2. We have configured SAML for SSO and there is a certificate that was being used in the older version with tomcat. Now that the system in on 4.8.2 and nginx is being used the SAML isn't working and best guess at the moment is the certificates need to be imported / moved to nginx. Anyone know what the steps are for doing this in CloudCenter 4.8.2 on the ccm?
Solved! Go to Solution.
Issue was caused by a defect in 4.7.x.x version. The SAML config had to be saved and exported updating the values and passed along to SSO team to update on that end. Once updated SSO worked.
FYI I have tried this solution from the documentation and it didn't resolve the issue;
http://docs.cloudcenter.cisco.com/display/CCD482/Certificate+Authentication
Ahh just saw your reply
Hi Chris,
I am not sure if you have worked with the C3 team on this but to resolve this all you’ve to do is regenerate the SP metadata on CloudCenter and export it to IDP.
Hope this helps
Cheers,
Mohit
