802.1X Authentication on 4507 switch using AD
techguy
Level 4
Level 4
I want to implement 802.1X authentication on Cisco 4507 switch. Authentication should be done thru Microsoft Active directory. Can someone guide me in this regard? Thanks
nspasov
Before you proceed with 802.1x based configuration make sure that your switch/Supervisor supports dot1x. Depending on the type of Radius server you are using the compatibility might change but here is the compatibility guide for Cisco's ISE:
http://www.cisco.com/c/en/us/td/docs/security/ise/1-3/compatibility/ise_sdt.html
With regards to configurations. Have a look at the following link (Again assuming you are using ISE):
http://www.cisco.com/c/en/us/support/security/identity-services-engine/products-implementation-design-guides-list.html
Thank you for rating helpful posts!
