ACS 3.0 authenicating with wireless AP 350 and AP1200
btibbs
ACS 3.0 for windows will not authenicate ap350 or ap1200. External database is windows 2000 active directory. Raduis server will not communicate with AP350 or 1200 using Leap. Do anyone know the correct configurations needed to successfully authenicate
tepatel
You jsut need to make sure that there is IP connectiviry between AP and ACS. Here is the link which has step-by-step config help for AP and ACS for LEAP.
http://www.cisco.com/warp/public/cc/pd/witc/ao1200ap/prodlit/wrsec_an.htm
ACS needs to be mapped for external database. Above link does have a pointer for that too.
