02-25-2009 12:39 PM - edited 03-10-2019 04:21 PM
I'm attempting to use an ACS 4.2 appliance to authenticate / authorize users on Brocade SAN switches. I have added the AVP and VSA to ACS, and they all show up in the web interface to select. When I configure a specific attribute for authorization level (ie., admin, user, operator, etc.), the authentication fails completely. Sniffer trace between the Brocade and the ACS shows the correct value for the AVP, but the VSA show "unknown-attribute" coming back from the ACS. The attribute shows the actual value I put in for the attribute, plus some other junk. Is there any way to "dump" the current AVPs / VSAs on the ACS to make sure things are correct? I've verified all the values are correct; just need some more eyes / ears.
Thanks!
07-29-2009 06:37 AM
Hi Mars,
I have the same issue. Has your problem resolved? If yes can you please share what needs to be changed to work this????
Appriciate your help.
REgards
Neha
07-29-2009 06:56 AM
No sir. I just went back to using local admin on the Brocade switches. I could not get ACS to work. It seemd like it was not getting the correct login information, etc. Neither Brocade or Cisco would own up to it, so I just went back to local users.
07-29-2009 07:15 AM
Hi imartino,
Would you like to add any comment on this???
Neha
