ACS 4.2 tacacs custom attribute for Nexus1000V
Eugene Khabarov
Level 7
Level 7
Dear All! Please, explain how to add tacacs custom attribute to ACS 4.2 for Nexus 1000V:
shell:roles="network-admin admin-vdc"
In the interface configuration I've added new service, service - shell, protocol - tacacs+.
In the group settings I've enabled this attribute configuration.
And it is not works. Default privilege level is assigned to any user with access allowed.
Screenshot is attached.
8 Replies 8
Tarik Admani
You should not have to add the shell tacacs service. Here is where you add the custom attributes:
http://www.cisco.com/en/US/docs/net_mgmt/cisco_secure_access_control_server_for_windows/4.2/user/guide/GrpMgt.html#wp479948
There should be a custom attributes box under the shell (exec) service, enter it there. You only need network-admin for the value.
Tarik
Thank you, but it was not helpful.
User recieves network-operator role:
Nexus1000V# conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Nexus1000V(config)# ?
  no        Negate a command or set its defaults
  username  Configure user information.
  end       Go to exec mode
  exit      Exit from command interpreter
Nexus1000V(config)#
aaa configured on Nexus like this:
aaa group server tacacs+ ACS
aaa authentication login default group ACS
aaa authentication login console local
aaa accounting default group ACS
in the debug I can see that correct attributes are recieved by Nexus:
2011 Jul 19 14:12:37.052510 tacacs: tplus_decode_author_response: attribute 0 service=shell
2011 Jul 19 14:12:37.052649 tacacs: tplus_decode_author_response: attribute 1 cmd=
2011 Jul 19 14:12:37.052789 tacacs: tplus_decode_author_response: attribute 2 shell:roles=network-admin
2011 Jul 19 14:12:37.052927 tacacs: tplus_process_vsa: got VSA attribute:shell:roles=network-admin
2011 Jul 19 14:12:37.053076 tacacs: tplus_process_vsa: got shell: home-dir: roles:network-admin uid:
2011 Jul 19 14:12:37.053223 tacacs: create_tacacs_user_profile: groups network-admin
thanks in advance for help.
UPDATE:
another interesting notification is that correct role is assigned to user, but configuration is not allowed:
sh user-account khabarov.evgeniy
user:khabarov.evgeniy
        roles:network-admin
account created through REMOTE authentication
Credentials such as ssh server key will be cached temporarily only for this user account
Local login not possible
nexus1kv-01# where
        khabarov@core-nexus1kv-01
core-nexus1kv# conf t
core-nexus1kv-01(config)# ?
  end       Go to exec mode
nexus1kv(config)#
Do you know if someone tampered with the user roles on your nexus? Also do you have the feature privilege enabled? try issueing a show feature to see if it is enabled and remove it and try authenticating again.
thanks,
Tarik
Hi! There is no such feature:
sh feature
Feature Name          Instance  State
dhcp-snooping         1         disabled
http-server           1         enabled
lacp                  1         disabled
netflow               1         disabled
port-profile-roles    1         disabled
private-vlan          1         disabled
sshServer             1         enabled
tacacs                1         enabled
telnetServer          1         disabled
I attempted to remove user from both Nexus and ACS and relogin againt and it was not helpful.
Can you send the output of the show roles?
Tarik
Hi!
core-nexus1kv-01# sh role
Role: network-admin
  Description: Predefined network admin role has access to all commands
  on the switch
  Rule    Perm    Type        Scope               Entity
  1       permit  read-write
Role: network-operator
  Description: Predefined network operator role has access to all read
  commands on the switch
  1       permit  read
Eugene,
Please open a tac case to have this issue looked at further, we will need to do more analysis.
Tarik
I have exactly the same problem with an ACS 5.2 returning the role attribute to Nexus 1000v. Remote user is authenticated but I can't run any privileged command even if the "show user" is good :
show user-account
user:admin
        this user account has no expiry date
        roles:network-admin
user:remoteadm
        roles:network-admin
Did you manage to make it work ?
Thank you,
Vincent
