ACS 5.3, a logging solution.
andrea.meconi
Level 2
Level 2
Hello.
We are using ACS 5.3 with two servers in a distributed solution.
All logs are collected on primary server so when this server fails all logs are lost.
How can I enable log on secondary server also?
Thanks.
Andrea
maldehne
Configuration -->logging categories --> log collector --> select the secondary
If you want to log locally and to secondary at the same time.
Configuration -->logging categories --> Remote Log Targets
create new remote logging target so that it points to the other server.
Please make sure to rate correct answers
Hello Maldehne and many thanks for your help.
I understand that with the first settings
Configuration  -->logging categories --> log collector --> select the  secondary - See more at:  https://supportforums.cisco.com/thread/2202554?tstart=0#sthash.5mYEZitx.dpuf
I can enable the log function on primary or on secondary server.
With the other settings I can log locally and to a remote target (the secondary server for me).
How can I view the log collected on secondary ACS? View is not running on secondary instance!
Thanks.
