ACS and AAA Help
jonchill
I've just configured ACS and TACACS+ for access to our switches using our AD for authentication. It works fine.
What I would like to know is firstly how can I configure ACS to only allow access to our switches if you belong in a particular AD group or ACS group as at the moment anyone can login to our switches if they are a user on the domain?
Secondly is there a way within TACACS+ to audit every single command that is entered while someone is loggin into a switch?
Any help would be much appreciated.
Jon
a.kiprawih
Level 7
Level 7
Hi Jon,
1. Refers to the previous post at:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40.1ddb89cb/0#selected_message
2.The audit feature that you're looking at is available for valid command once the user/admin entered 'conf t' command.
The following command can be used to monitor what commands are being entered by the user/admin:
aaa accounting network SAMPLE start-stop group tacacs+
You can see the report under ACS's "Logs and Reports" section - look for tacacs+.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca7aa.html#wp1005522
*can also look under sample config.
Rgds,
AK
