acs se 1113 - manually set ip does not work
rhub
hello everybody
i have 2 new acs 1113 (code-level 4.0(1.44).
setting manually ip-address, subnet-mask, dns during initial configuration of the ACS SE via serial cable/ terminal emulation is ending with the error-msg "Cannot set new NIC configuration".
performing a "show ip" displays the factory defaults (e.g. dhcp=yes)
screen-shot:
set ip
Use Static IP Address [Yes]:
IP Address [169.254.253.207]: 10.100.201.109
Subnet Mask [255.255.0.0]: 255.255.255.0 Default Gateway []: 10.100.201.1
DNS Servers (Separate multiple servers with a space) []: 10.100.202.100
10.100.202.101
New Configuration:
DHCP: No
IP Address: 10.100.201.109
Subnet Mask:255.255.255.0
Default Gateway: 10.100.201.1
DNS Servers:10.100.202.100 10.100.202.101
IP Address is reconfigured.
Confirm the changes? [Yes]:
Error: Cannot set new NIC configuration
any hints are very welcome
thanks very much for support
roman
hello
thanks very much for your reply. yes, i used this nic but i solved the problem by myself. i had to reimaging the acs-box from the recovery cd and everything was o.k. knows the hell why :-)))
