Best way or correct way to reload 2 ise nodes (pan/mnt)
ade5
Hello everyone
I need to reload two ise nodes due to a bug that caused licensing consumption page to show zero. ise1 primary(pan/mnt)  and ise2 Secondary(pan/mnt). I have 4 psn nodes and they should stay up. I need to ensure no downtime. I know I have to do both config and operational backup first.
option1
send reload command to secondary node first and wait for it to come back up then reload primary
option2
promote secondary to primary then reload ise1 and when ise1 comes back up switch ise2 back to secondary
please let me know if those options are valid and which is best or if there are other options. Thank you!
Damien Miller
Just reload them as in option 1. If you do option 2 you have double the reloads, when you promote a node to primary it reloads again.
If you read this section of the admin guide you can see what services will be unavailable while the Primary PAN reloads. Reloading the PAN is a common task, no need to over think it.
https://www.cisco.com/c/en/us/td/docs/security/ise/2-4/admin_guide/b_ise_admin_guide_24/b_ise_admin_guide_24_new_chapter_011.html#ID59
5 Replies 5
mnagired
Dont see much difference between Option 1 or 2.. with Option 2 you can get back to same state(ISE1- Primary and ISE2- Secondary)..
Yes, Make sure you perform a configuration and operational backup and use application stop ise & Halt CLI to Shutdown ISE instances and reduce any database corruption..
Mahesh
"Yes, Make sure you perform a configuration and operational backup and use application stop ise & Halt CLI to Shutdown ISE instances and reduce any database corruption"
thank you. Are you saying its better to shut it down rather than sending the command "reload"?
Damien Miller
thank you Damien.
This is exactly what I was looking for.
Thanks!
