Can Cisco ASA work with spaces in LDAP DN string to authenticate and assign group policies?
charlesriley
I am having the hardest time getting a definitive answer to this;  basically, I have a Cisco ASA firewall that is using AD via LDAP to authenticate  users and assign them a group policy based on certain AD group memberships.
The problem I think I have is that due to how our AD forest is structured, I have spaces in the DN string, as shown below...  I have tried enclosing the entire string in quotes, etc.  - nothing seems to work.  Basically, the string is not matched, and the users are assigned a non-matching default policy.  Cisco TAC thinks it is due to the spaces (highlighted) but I am not sure sure.
Can some one please advise?
CN=VPN_SSL_SPLIT,OU=Grps - ACS,OU=Res - Groups,OU=BU - Vesna.Resources,DC=DOM1,DC=US,DC=LOCAL
5 Replies 5
Jatin Katyal
Yeah It does work!  All you need to have the DN with spaces in quotes like this:
ldap attribute-map LDAP-MAP
  map-name  memberOf IETF-Radius-Class
  map-value memberOf "CN=VPN_SSL_SPLIT,OU=Grps - ACS,OU=Res - Groups,OU=BU - Vesna.Resources,DC=DOM1,DC=US,DC=LOCAL" <Group Policy Name>
This will make the DN as a single entity and will not truncate when it read spaces.
In case you want to verify the same, run debug ldap 255 and look into it.
Jatin Katyal
*Do rate helpful posts*
~Jatin
I have tried it with the quotes as suggested and it still does not work.  I wonder if I have something else wrong, though I have checked and rechecked the DN strings and configuration repeatedly.
We can troubleshoot this issue. Please provide me the following outputs:
show run aaa-server
show run ldap
Turn on "debug ldap 255" and reproduce the issue. Paste the output here.
Jatin Katyal
~Jatin
I having the same problem. I have a windows 2003 using RADIUS, but when using LDAP doesn't work. I got the error: Authentication Server not responding: AAA server has been removed
Please provide the same information:
show run aaa-server
show run ldap
Jatin Katyal
**Do rate helpful posts**
~Jatin
