Can not authenticate Cisco Access Point with EAP-FAST
I try to authenticate Access Point using EAP-FAST. I did everything that is described here:
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-fixed/107946-LAP-802-1x.html
Although username and password are the same in Cisco ISE local database and AP I have an error:
5400 Authentication failed
22063 Wrong password
Could you please help me with that issue?
17 Replies 17
The documentation shows a different authentication host-mode for the Flexconnect AP (should be multi-host rather than multi-auth as you have).
Your original switchport config looked ok:
interface GigabitEthernet 1/0/1
switchport access vlan 100
switchport mode access
spanning-tree portfast edge
Once ISE authorizes with RADIUS attribute device-traffic-class=switch it should change to:
switchport trunk native vlan 100
switchport mode trunk
spanning-tree portfast trunk
hth
andy
Marius Gunnerud
In what order did you configure this?  I mean, did you configure the switch first, and then WLC and ISE?  If you configured the switch before the WLC / AP this might be the reason it is failing as the dot1x configuration has not been pushed to the AP
Please remember to select a correct answer and rate helpful posts
Hi All,
There is a bug indicated in this link:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvn18615
I upgraded my WLC and now I can authenticate APs using EAP-FAST.
