Cisci ISE and forescout in same network
adamgibs7
Level 6
Level 6
Dears
I would like to use the ISE for the tacacs and guest network and forescout for the rest of the services, can i add both of them in the switches and routers, how things will work in this case the authentication will work with ISE and the dot1x and other features will work with forescout,  is this type of setup will work? and how,
The different between ISE and forescout is ISE works before the machine/windows gets the IP address and the forescout works post machine/windows come's up.
thomas
You may configure TACACS+Device Administration AAA servers separate from RADIUS AAA servers in Cisco IOS. "forescout for the rest of the services" is not very specific but it will likely involve making one of your AAA server deployments (ISE or Forescout) a RADIUS proxy for the specific services they are handling.
That is not 802.1X + RADIUS with ForeScout - that is the SNMP Authentication VLAN method.
balaji.bandi
yes this possible based on the configuration you doing for device admin and SSID configuration for Guest you can point to ISE
Other part you mentioned -  forescout for the rest of the services,  - this was not clear - is this for 802.1x  for Wire and Wireless ?
if you using 802.1x  for Wired connection then that will be difficult  i guess my views.
BB
Dear balaji
the rest services are :
  • DOt.1x
  • profiling
  • posture
  • BYOD
  • Rapid threat containment
Never tried it with different vendors - look at below example may help you  and may meet your requirements :
https://www.cisco.com/c/en/us/td/docs/wireless/controller/ewc/17-2/config-guide/ewc_cg_17_2/authentication_and_authorization_between_multiple_radius_servers.pdf
BB
thomas
