Cisco ACS taccas+ issue with authentication
ncharaipotra
I am having an issue authenticating on a switch using taccas+ on my ACS 5.2 server. I can actually do a "test aaa group taccas+ username password legacy" and it returns a successful authentication for the user. When I try to use that same account to authenticate the switch, it is unsuccesful and I don't even see the attempt hit the ACS.
fibrahimsha
Most probably is a miss configuration of the AAA command on the switch.
fibrahimsha
Richard Burts
Perhaps if you post the config we might be able to find an issue.
Rick
Rick
