Cisco ISE 1.3 using 802.1x Authentication for wireless clients
aevans
I have stumbled into a strange issue trying to authenticate a user over wireless. I am using PEAP as the authentication protocol. I have configured my authentication and authorization policy but when I come to authenticate the authorization policy selected is the default which denies access.
I have used the 802.1x compound conditions for matching the machine authentication and then the user authentication
MACHINE AUTHENTICATION
match
framed
Wireless
AD group (machine)
USER AUTHENTICATION
match
framed
Wireless
AD group (USER)
was authenticated = true
Below are steps taken to authenticate any ideas would be great.
11001  Received RADIUS Access-Request
  11017  RADIUS created a new session
  15049  Evaluating Policy Group
  15008  Evaluating Service Selection Policy
  15048  Queried PIP
  15048  Queried PIP
  15048  Queried PIP
  15006  Matched Default Rule
  11507  Extracted EAP-Response/Identity
  12300  Prepared EAP-Request proposing PEAP with challenge
  11006  Returned RADIUS Access-Challenge
  11018  RADIUS is re-using an existing session
  12302  Extracted EAP-Response containing PEAP challenge-response and accepting PEAP as negotiated
  12318  Successfully negotiated PEAP version 0
  12800  Extracted first TLS record; TLS handshake started
  12805  Extracted TLS ClientHello message
  12806  Prepared TLS ServerHello message
  12807  Prepared TLS Certificate message
  12810  Prepared TLS ServerDone message
  12305  Prepared EAP-Request with another PEAP challenge
  12304  Extracted EAP-Response containing PEAP challenge-response
  12812  Extracted TLS ClientKeyExchange message
  12804  Extracted TLS Finished message
  12801  Prepared TLS ChangeCipherSpec message
  12802  Prepared TLS Finished message
  12816  TLS handshake succeeded
  12310  PEAP full handshake finished successfully
  12313  PEAP inner method started
  11521  Prepared EAP-Request/Identity for inner EAP method
  11522  Extracted EAP-Response/Identity for inner EAP method
  11806  Prepared EAP-Request for inner method proposing EAP-MSCHAP with challenge
  11808  Extracted EAP-Response containing EAP-MSCHAP challenge-response for inner method and accepting EAP-MSCHAP as negotiated
  15041  Evaluating Identity Policy
  22072  Selected identity source sequence
  15013  Selected Identity Source - AD1
  24430  Authenticating user against Active Directory
  24325  Resolving identity
  24313  Search for matching accounts at join point
  24315  Single matching account found in domain
  24323  Identity resolution detected single matching account
  24343  RPC Logon request succeeded
  24402  User authentication against Active Directory succeeded
  22037  Authentication Passed
  11824  EAP-MSCHAP authentication attempt passed
  11810  Extracted EAP-Response for inner method containing MSCHAP challenge-response
  11814  Inner EAP-MSCHAP authentication succeeded
  11519  Prepared EAP-Success for inner EAP method
  12314  PEAP inner method finished successfully
  24423  ISE has not been able to confirm previous successful machine authentication
  15036  Evaluating Authorization Policy
  15048  Queried PIP
  15048  Queried PIP
  24432  Looking up user in Active Directory - xxx\zzz Support
  24355  LDAP fetch succeeded
  24416  User's Groups retrieval from Active Directory succeeded
  15048  Queried PIP
  15048  Queried PIP
  15004  Matched rule - Default
  15016  Selected Authorization Profile - DenyAccess
  15039  Rejected per authorization profile
  12306  PEAP authentication succeeded
  11503  Prepared EAP-Success
  11003  Returned RADIUS Access-Reject
  5434  Endpoint conducted several failed authentications of the same scenario
Windows will only machine authentication when you are booting up, so when testing you can't just disconnect/connect the pc, you need to reboot. The solution to this is called cisco anyconnect nam, and eap-chaining.
6 Replies 6
KiloBravo
Judging by that line and what your policy says, it appears that your authentication was rejected as your machine was not authenticated prior to this connection.
first thing to check is whether MAR has been enabled on the identity source. second thing to check is whether your machine is set to send a certificate for authentication. there are other things you can look at but I'd do those two first.
log off and on  or reboot and then see if you at least get a failed machine auth on the operations>authentication page and we can go from there.
I can confirm it is to do with the machine authentication not happening, I changed the Authorization rule to just do AD log in and client connected when using an IPhone failed with a corp laptop.
I have tested with MAR enabled and disabled and still no access.
I have requested a fresh build laptop with a new GP update just for this laptop for a true test.
Any further ideas?
you need to see why it is failing machine authentication, if it is being passed to ISE there will be an entry for it on the operations>authentications page. If you can get the output for a machine auth failure then we can troubleshoot from there.
That's the issue It doesn't seem to be even trying to authenticate...
Regardless of how I configure the windows adapter I always hit the default rule!
as JAN mentioned, how are you trying to get it to re-authenticate when testing? machine authentication on windows usually occurs on lo on/log off or a reboot.
secondly you may want to disable suppression on that particular machines mac address as this will prevent it from coming up in the live authentications.
if you're already applying the above then screenshot your peap setings from the client and let's see how its configured.
