Cisco ISE 3.0 hot fix patch- do we need to remove expired certificate
anilkumar.cisco
Enthusiast
Enthusiast
Hello Team,
During patch or hotfix installation, do we need to remove expired certificate.
Actually one of the trusted root certificate is expired , not sure what is the use of that..
Also, pls let me know during hotfix upgrade , do we need to restart the ISE server..
2 Accepted Solutions
Marcelo Morais
VIP Advisor VIP Advisor
VIP Advisor
Hi @anilkumar.cisco ,
 expired Certificates may cause ISE upgrade to fail, in other words, it's a good practice to remove expired Certificate before Patch or Hot Patch installation.
Note: please check the Hot Patch Release Notes, but an Application Server restart is something expected during a Hot Patch installation.
Hope this helps !!!
If a trusted root certificate has expired, then anything that was using it would already be broken. A couple of the built in certs provided by Cisco have been replaced with alternates in later builds/patches and but the old remained.
Marcelo Morais
VIP Advisor
Hope this helps !!!
in hot patch upgrade or ISE Patch upgrade procedure.. non of the place this statement is written to remove expired certificate  thus got confuse..
I am also not sure what is the use of that certificate..
As it is trusted root certificate.. but i found the similar trusted valid certificate as well on the system.
Don't want to take risk with certificate so need advise.
Recognize Your Peers
