Cisco ISE problem redirecting to the portal
sedovsergei100
I have a Cisco ISE and WLC. A redirection profile to the portal is configured on Cisco ISE.
Access Type = ACCESS_ACCEPT
cisco-av-pair = url-redirect-acl=GUEST_ACL
cisco-av-pair = url-redirect=http://portal.website.com
Everything works well.
But when I give full access to the Internet in the ACL (GUEST_ACL), redirection to the portal stops working.
10 Replies 10
sedovsergei100
the "portal.website.com" is on my network
What "WLC"?  AireOS?  9800?
GUEST_ACL should NOT be full internet.  It should only allow DHCP, DNS, and Access to the ISE PSNs.
https://community.cisco.com/t5/security-knowledge-base/ise-guest-access-prescriptive-deployment-guide/ta-p/3640475
WLC - Cisco 5520 Wirless Controller
I need the devices to have full access to the external network at the time of transition to the portal.
Ideally
ACL - permin any any
But with such a ACL the transition to the portal is not carried out.
It was experimentally established that
ACL
deny any 104.86.110.0/24
permit any any
It can open a portal on devices with the Windows operating system, but on mobile devices (Android, iOS) the transition is not carried out.
What do you mean by "transition"?  You need to have a redirect ACL to actually "redirect" traffic to the portal. Why are you permitting all traffic before the client logs into the portal?
The general idea is this. The user connects to WiFi. ISE assigns it security group 1 and redirects it to the internal network site. Now the user can perform actions in accordance with the policy for SG1 on FirePower. To do this, I need to allow full access to the user on the WLC when going to the site
"internal network site" - is this an ISE Guest Portal?  Something else?  Please read this guide, especially the portions on the redirect ACL: https://community.cisco.com/t5/security-knowledge-base/ise-guest-access-prescriptive-deployment-guide/ta-p/3640475
The wireless controller should be managing the ACL, not the upstream firewall.  Once the user has authenticated to the portal then assign the appropriate security group.
sedovsergei100
"internal network site" - is not a Cisco ISE portal. This is a website and information for guests.
In document https://community.cisco.com/t5/security-knowledge-base/ise-guest-access-prescriptive-deployment-guide/ta-p/3640475 in section "Configure an ACL to Redirect Guest Devices to the ISE Guest Portal", paragraph 8, the ACL that I need is indicated.
The problem is that with this ACL the transition to the site using:
cisco-av-pair = url-redirect=http://portal.site.com
With the ACL from "Configure an ACL to Redirect Guest Devices to the ISE Guest Portal", paragraph 7, the user will be redirected to the site.
Oh, now it makes more sense.  Why are you doing redirect then at all?  What exactly are you trying to achieve?  ISE will not redirect to a non-ISE portal.  You need to handle that redirection directly on the WLC.
https://www.cisco.com/c/en/us/support/docs/wireless-mobility/wlan-security/71881-ext-web-auth-wlc.html
https://www.cisco.com/c/en/us/products/collateral/wireless/5520-wireless-controller/eos-eol-notice-c51-744430.html
sedovsergei100
If I redirect a user to a site using a WLC, I will not be able to assign a security group (TrustSec) to him.
I can only do this on ISE
cisco-av-pair = cts:security-group-tag=0003-7
cisco-av-pair = cts:sgt-name=SG3
cisco-av-pair = cts:vn=
Tunnel-Private-Group-ID = 1:
Tunnel-Medium-Type = 1:13
Tunnel-Type = 1:6
On the WLC you can assign the SG value to the SSID. But how can you force devices to open a website page when connected?
