CiscoSecure 3.3 Problem
Frank Durham
Level 2
Level 2
I am trying to set up 802.1x via the CiscoSecure 3.3 Trial for windows. I have installed the application properly and have configure the clients and configured my switch for authentication. When I go to install the certificate by follwing the instructions from cisco and turn on the EAP-MSCHAPv2; I get the follwoing error.
"Failed to initialize PEAP or EAP-TLS authentication protocol because ACS certificate is not installed." I don't understand this error because I have installed the certificate correctly according to the documentation.
Any help is appreciated.
Frank
7 Replies 7
owillins
Level 11
Level 11
EAP-TLS requires support from both the end client and the AAA client.
tom.paul
Community Member
Generate your certificate with cn=hostname or better cn=hostname with FQDN.
ecarrasquillo
Community Member
Frank,
In order for the 802.1x authentication using EAP-MSCHAPv2 to occur you need to install a certificate from the system configuration menu. Be aware that you will need a certificate server when you generate the CSR.
marcbutler
Level 3
Level 3
Hi Frank
Well, I am having the very same error come up and am having the same sort of problems fixing it (even though I am deploying NAC as opposed to .1x auth).
I notice that none of the above comments were very helpful. If I find the answer, then I will make sure that I post it here for you.
However, I hope you have already found a solution.
Rgds
Marc
Marc-
I did get the solution. The problem was i was trying to install the certificate from my subordiante CA server. I had to install it from the Root CA server. If you need some help let me know, as I am about to plan for NAC deployment as well.
Frank
Hi Frank
Any help would be much appreciated. I am pretty sure that I am installing from my Root CA (having just installed the CA part on the server) although now coming to think of it, that server is not in my domain. Could that be the issue? I know that the CA does not need to be a DC, but can be one, but I have never really thought whether it makes a difference if it is a member of the domain or not!
Yes, any help would be much appreciated, Frank.
marcbutler
Level 3
Level 3
Hi Frank
Yes, if you could outline what helped you, that would be great!! I have now realised that my CA is indeed a root CA and that it definitely was/is part of the domain, (but not a DC, but that should not be an issue).
Anything that you could suggest would be much appreciated, as I am banging my head against a brick wall with this one.
Rgds
Marc
