Configuring 802.1X port-based authentication with VLAN assignment
tvanginneken
Level 4
Level 4
My client-pc is connected to a C2950 switch that is configured for 802.1X port authentication. The C2950 switch forwards the pc authetication request to a Cisco ACS Radius server version 3.2.
Which RADIUS attributes need to be set on ACS Radius server to use VLAN assignment and what TAGs do I need to set (0,1 or 2) and what values need to be set for these radius attributes. Up to now I have found the following attributes in the documentation:
[64] Tunnel-Type=VLAN
[65] Tunnel-Medium=802
[81] Tunnel-Private-Group-ID=vlan-name
I tried these attributes but it doesn't work.
The documentation does not specify the TAGs I should use.
Could someone help me out please??
Thanks!!
Tom
21 Replies 21
I 've tried to configure using the following command on the 2950 Cisco Switch
2950# configure terminal
2950(config)#aaa new-model
2950(config)#aaa authentication dot1x default group radius enable
2950(config)#dot1x max-req 3
2950(config)#dot1x timeout quiet-period 0
2950(config)#dot1x timeout re-authperiod 1
2950(config)#radius-server host x.x.x.32 auth-port 1812 acct-port 1813 key 123
2950(config)# interface fastethernet 0/1
2950(config-if)# dot1x port-control auto
2950(config-if)# end
On the ACS I configure as cisco(ITEF) withe the switch IP and key 123
But when I try use peapon XP SP1 0s with the debug I encounter ABORT on the authenication , Can U point out where did I went wrong
Mc
can you post the debug, debug aaa auth, and debug radius
Dear mschooley
i have tried the same configuration, a vlan is dynamically assigned to the dot1x user, as i am able to ping only that particular vlan. An ip is going out from ACS to switch , but then it vanishes.
Any help , greatly appreciated.
regards
kalyan
Hi Mschooley,
Have you tried Microsoft patch 822596? How is it? I tried this patch but met some problem. The client will ping its default gateway after receiving Authentication sucsessful message from switch. If the client can't ping the gateway, it will do a IP address renew. But I find the switch is a bit slow in switching vlan. When client ping default gate, the vlan is not switched yet. And it causes the client fail to get new IP address. Have you met this kind of situation?
Thanks and Regards
Deng Qi
just tested with my laptop, worked ok, in the next couple of weeks we are going to implement in larger test environment, will update you then,
I'm doing a machine authentication against the ACS db and i keep geting an error during the 802.1x authentication process regarding the password. Do you know what password the Windows machine uses during the machine authentication?
